Question about Kenmore Microwave Ovens
Kenmore microwave model 970-86133-001 is 4Y old and suddenly stopped heating
Posted by Bev Budden on
5 Related Answers
Anonymous
SOURCE: GE SpaceMaker Microwave suddenly stops while heating
I had same problem last week. My GE JVM1650 Spacemaker stopped after a few seconds of heating. Owned 16 months, manufactured Jan 2005. It was the magnetron, which was replaced yesterday. The magnetron has a 10-year warranty, but I had to pay $161.00 for labor by a GE technician. The call-out fee was waived at my request. I don't know what that amount would have been, but I can't believe the $161.00 for what was about 1/2 hour labor once diagnosed. Good Luck!
Posted on Sep 21, 2006
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: KENMORE MICROWAVE (HOUSEHOLD) LOCKED
It sounds like you press STOP two or three times to lock it. Maybe that (or another key) will unlock it.
The lock / unlock procedure will be covered in your owner's manual.
Or you can try a hard reset - unplug it from the wall for one minute, then plug it back in and try again.
If you don't have your manual, you can get one here. (Enter your model number without any spaces)
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 01, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: kenmore galaxy microwave model 721.80002 1500 watts does not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Dec 22, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: cookworks microwave not heating up
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
If for some reason you don't have your owner's manual, I would suggest calling the dealer where you bought it to see if they have a number for Cookworks.
Posted on Jan 04, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: My Kenmore Microwave Hood Combination Model
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 23, 2010
Kenmore microwave model 7210413500 suddenly stopped heating. What are the steps I might take to troubleshoot and diagnose the probelem. Is there another microwave that can replace this model in the s
Model nimber is blocked out for some reason. But dont try to repair a microwave unless you understand how to work with high voltages. The voltages you are dealing with here are lethal. You must discharge the capacitor before any work can be done. Generally only two parts are do most of the failures, the diodes an the large capacitor. If you do not have the proper gear to test leave it alone. The cost to repair is usually runs higher than the cost of a new microwave.
My Kenmore Microwave, only a couple of years old, suddenly stopped heating. Everything else works fine. Model # 721.63242300
read the info on the below link, it was posted by me;
http://www.fixya.com/support/r7088553-microwave_oven_not_heat_hear_loud
Good luck.
Have a cookworks microwave model AM821AHT-X2, only 6 months old and just suddenly stopped working properly,not heating up,timer and lights are working but no heat at all.
Basic Microwave Oven Troubleshooting Tips
heatman101
My 2 year old Kenmore Microwave Model 721.66229 just stopped working. The light comes on when you push start, but the tray will not rotate and no heating happens. Help??
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101[p][p]
Microwave oven suddenly stopped working, no display,not outlet
Hi, you must check the inside fuse. If is burned out, please consider that something happened, you must check further beyond to find the causes.
Microwave stopped heating
I had the same oven for one and a half years and had the same problem. Had the sears repairman come out and he said the magnetron burned out and needed replacing for $285. It was never under warranty with the warranty that came with oven. I couldn't believe it! We had an independent repairman look at it and he found a design flaw that causes the magnetron to blow. If you replace the matnetron (megnatron?) it will work for awhile, maybe, but then just need to be replaced again. It's cheaper to buy a new microwave. In fact, I got out our old microwave that's over 20 yrs. old and still works--just isn't as fast and as new ovens. Good luck!
2answers
My kenmore ELITE 721.64282 microwave/convection just stopped
I just had the exact same problem. :( Did you find anything out?
2answers
Kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
Microwave suddenly stopped working
Code F3 indicates an open / defective thermistor / temperature sensor. The first suspects when a microwave is not heating would be the door switches, bad connections on the magnetron terminal or bad connections on the control board. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Microwave Ovens Logo
Top Kenmore Microwave Ovens Experts
Gerry Harvey
Gerry Harvey
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
