Question about Simplicity Vacuums
It's my simplicity vacuum cleaner that needs new on-off switch, not an electronic device
Posted by Naomi Carlson on
Thatvacguy.com
  • Simplicity Master
  • 1,604 Answers
Get a new switch from your dealer
Posted on Oct 23, 2018
2 Related Answers
Anonymous
SOURCE: How do I replace the electric cord for my
Since the problem was with the plug on the electric cord, I replaced the plug, I cut the old plug, peel off the plastic cover on the cord, they were two wires, black & white, I purchased a new plug in a Home center, attach the wires to the new plug and it works just beautiful now, it was a two prong plug, which made it easier to fix.
Posted on Feb 17, 2010
askdyson
AskDyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: Need to buy new battery charging device for the
    If you want to purchase a new charger assembly, you can order one directly from Dyson. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). Alternatively, you can order one online from www.dyson.com.
    Kind regards,
    Jack
    Dyson Customer Service
    Posted on Aug 08, 2011
    How do I replace the roller switch?
    Make sure the tool lever is all the way clockwise. It activates a switch that controls the brush roll.
    Jan 25, 2015 | Simplicity Riccar Synchrony Upright Vacuum...
    I turn it on and nothing happens,
    I would double-check the seating of the bag. Some machines have a lockout switch that keeps you from running the vac with a bag incorrectly installed (which would then suck dirt into the motor).
    Mar 16, 2014 | Simplicity Type S Sport Vacuum Cleaner...
    I have a simplicity freedom F3700.2 upright vacuum. It has been working wonderfully until now. I plug it in and it won't start. I have tried removing the bottom and cleaning the roller, the bag isn't...
    Sounds like a break in cord or plug somewhere. I am not familiar with the particular vacuum myself. Another thought I have when looking around your vacuum cleaner have you seen a red reset button anywhere at all?
    Or by chance does your vacuum cleaner have a plug comes off....... (i.e. like a computer)
    a few thoughts
    I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
    Sep 02, 2013 | Simplicity Vacuums
    Burnt rubber smell when vacuuming
    This could be a few things:
    A. If your model has a floor selector switch (Bare floor/tools - Carpet) your clutch could be worn. (there is a rubber clutch pad between your cam and roller shell) - Fix would be to replace the clutch pad and belt.
    B. If you don't have one of the above models, your belt could be stretched. The belt slipping could cause a rubber burning smell. Fix - Change belt.
    C. Have you got any new carpet you are vacuuming or have you moved? Some of the newer style frieze carpets can cause burning rubber smell. The fibers of the carpet are longer and cause the brush to slow down causing the belt to burn. (Imagine brushing long hair with a thick brush, the hair easily gets tangled in the brush, same effect with this carpet.) Some of the newer rugs can do this as well. Some newer carpets with the thicker felt backing and/or the "pet padding" under the carpet can too. it doesn't allow enough air to flow through causing the cleaner head to seal itself to the carpet causing a burning smell. The fix is Move to another home, replace your carpets or replace your vacuum. The vacuum is the cheaper option but be cautious as most vacuums now do this with these carpets. We have had really good response from customers using the Simplicity Tandem Air models, (Synchrony and Synergy models.)
    Hope this helps, if you need to talk further feel free to contact me.
    Tim
    TheVacCenter.com
    Mar 13, 2013 | Simplicity Vacuums
    I have a 6550 that just stopped working. I had the on/off switch tested to find out that it was dead. I replaced it and still the machine does not work. Could the wiring in the handle be bad? How do you...
    I test a motor by taking an old vacuum cleaner cord with alligator clips on the ends and hook it up to the motor simply bypassing the entire vacuum cleaner. If it runs then I know the problem is not the motor.
    Jul 27, 2010 | Simplicity Vacuums
    How do I replace the electric cord for my Simplicity Shadow Vacuum cleaner model S13L? It's a canister cleaner.
    Feb 16, 2010 | Simplicity Vacuums
    I have a simplicity 6 series vacuum. the bag overfilled and vacuum will not run. No power. is there a fuse of relay inside the unit?
    no just on /off switch and direct power to vac motor sounds like its burned up from bag being overfilled , now you have to get to the vac motor test it with switch on to see if its getting power if so then motor is burnt.use an ohms meter for power test.
    Feb 07, 2010 | Simplicity 7250 Deluxe Vacuum
    Changing the belt
    http://geeksquad.fixya.com/ThreadView.aspx?prdid=83009&thid=695737
    Changing the belt
    Posted by cbgolba on Jun 22, 2008
    My husband changed the belt on our vacuum, now the metal frame doesn't fit back on the bottom. Also, there is a small metal clip that we don't know where it belongs.
    I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You should check on the owner’s manual to see how it goes together or call the Simplicity customer service line listed below to see what goes where. It’s been awhile since I have worked on a simplicity vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
    http://simplicityvacuums.com/ Customer Service 1-888-9-Simply
    Thanks, Don the Vac Man
    Go Ahead. Use Us.
    Jun 22, 2008 | Simplicity 7850 Premier Bagged Canister...
    Vacuums Logo
    129 people viewed this question
    Top Simplicity Vacuums Experts
    ray gallant
    William Wright
    Are you a Simplicity Vacuum Expert? Answer questions, earn points and help others
