A
Art Heaton Posted on Aug 31, 2018
What is the ir sensor part number for an Onkyo TX-DS575?
5 Related Answers
Anonymous
  • 752 Answers
  • Posted on Dec 18, 2007
SOURCE: Need fiber optic input jack for Onkyo TX-DS575
Had it ever worked, or are you setting it up for the first time?
Have you ASSIGNED the digital input in the menu?
Rob Galayda
  • 54 Answers
  • Posted on Nov 15, 2008
SOURCE: Onkyo TX-DS575 - intermittent audio
You have a problem that was inherent with all Onkyo receivers from this period. You need to contact Onkyo because the microprocessor needs to be replaced. Last I checked, its about $80 from onkyo.
This is NOT an isolated incident as darn near every Onkyo receiver model had this problem.
Good luck...
Rob
Anonymous
  • Posted on Mar 28, 2009
SOURCE: i need the remote code for my onkyo tx-ds575, my
Get yourself a remote from Logitech Harmony family. It magically knows all the possible codes. And the support is VERY helpfull.
Marek Michalczyk
  • Posted on Jun 12, 2009
SOURCE: Onkyo TX-DS575X, remote intermittend malfunction
You have to raplace IR sensor PIC-26043TE2 or similar and should help.
smarthome2
Frank Fulton
  • 1114 Answers
  • Posted on Jul 05, 2009
SOURCE: Left speakers are not working on my onkyo tx-ds575
Check the units internal "menu" settings for speakers and audio. beyond that, there would be an internal problem and neded service. Hope this helps
I have lost the remote control of my Onkyo TX-DS575 AV reciever/DTS Amp and cannot find one in the market. I have used a universal remote which had a couple of Onkyo codes with it but it doesn't work. Is...
Amazon.com, MyRemoteControls.com, and Remotes.com all sell a replacement remote for the TX-DS575. I have also seen the Onkyo TS-DS575 receiver with remote listed on eBay for as low as $35. Keep looking; the remotes are out there.
3helpful
3answers
I have a TX-DS575 receiver and RC-391M remote control and the remote no longer controls the receiver, but it still controls all the other components (dvd, tv, etc). How can I get it working with the...
Replace the IR receiver diode on the front panel. Try HERO HIM602H from farnell.com, i used that one for my TX-DS 777. (i guess 575 using same stuff)
2helpful
OWNERAS MANUAL TX DS575
You can get the manual on the link below.
http://www.intl.onkyo.com/downloads/manuals/pdf/tx-ds575x_manual_e.pdf
If that is not the right on then go to this link below and click where it says it is free
http://safemanuals.com/user-guide-instructions-owner-manual/ONKYO/TX-DS575-_E
Good Luck and please rate 4 thumbs up for the free answer
2answers
Remote doesn't operate reciever
Hello Fixya customer,
Thank you for your question.
Please determine if the "Audio" button is actually working.... after pressing the audio button, can you still control the DVD, if not then the remote has switched to the Onkyo. Although, this is not 100% conclusive, unless you have a 2nd remote to test the Onkyo with, it provides a sound basis to proceed.
Assuming the remote is transmitting and the IR receiver on the front of the Onkyo is not otherwise blocked, likely faults include the IR receiver, input to the Micro processor, and the Micro processor.
The most probable fault is the IR receiver.
Thank you for using Fixya, and if I can help you further, please let me know.
Unit does not respond to remote control
I had this same problem with the Onkyo TX-SR706 this evening, and finally found the solution in the "Controlling Other Components" section of the manual: Resetting the remote control did the trick. (P.S. This problem started after I spent many hours today trying to get my new Acer laptop equipped with a Hauppauge TV tuner stick to correctly display its image on my Samsung HDTV, with sound. I tried connecting the laptop via HDMI first to the Onkyo receiver and then directly to the TV, neither of which worked as it should. I assume that somehow, in all those hours of much plugging and unplugging and fiddling around, I screwed up the remote sensor -- thank goodness I eventually found the "Resetting the Remote Controller" solution a little while ago -- I was approaching the point of ripping everything apart and throwing it out the window!)
1helpful
Good luck...
Rob
11helpful
3answers
2helpful
Will not power up but stand by light is powerd up
I have onkyo tx-ds575 and i need to conect it to my tv and have audio from a LCD flat panel.
1helpful
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
