Question about Building Materials
After a close lightning strike. neither of my Liftmaster Pro openers -- models 1160LM and 3265 -- will work.
Both outlets have power, and the push-button transmitters are lit, but there is absolutely no response from either opener.
Posted by Randy on
mehan
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Call your homeowners ins co. The control panels are most likely fried. Will need to be replaced.
Posted on Apr 19, 2019
5 Related Answers
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: Garage Door Opener Intermittingly Reversing
try adjusted the sensor controls on the sode of the unit other wise replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Posted on Jan 10, 2008
Verne Koti
  • 476 Answers
SOURCE: Liftmaster 1280 LMC Motion Detector Garage Opener Push Button Pad Not Working
Have you tried to reprogram the chanel again?
Changed the battery?
Posted on Aug 02, 2008
Anonymous
  • 512 Answers
SOURCE: Remote Entry System not working, 05 Chrysler T&C
there is an update foe the body control module that will generally fix the problem. you will ned to take it to the dealer to have it done.
Posted on Jan 03, 2009
jpnuke115
  • 4 Answers
SOURCE: My 2003 LIncoln Navigator liftgate is not working.
check relay and fuses,make sure that automatic liftgate is on. You will have to to the command center and go through the defaults and make sure that the system is on. if you are not comfortable doing that, disconnect battery for approximate ten minutes, this will reset the system defaults.
Posted on Jul 23, 2009
Don Maggard
  • 3197 Answers
SOURCE: Liftmaster wireless keypad closes but won't open the door
If you are sure the battery is good you have a bad keypad. The signal strength is so weak it will not penetrate the door.
Posted on Aug 25, 2009
Liftmaster 3265M. Two units. Why does neither work since lightning storm?
Chamberlain Liftmaster garage door opener problems ...
? 3:10
https://www.youtube.com/watch?v=Zq_CxeTXoSM
Jul 2, 2013 - Uploaded by Mike McCarron
Might have taken a lightening strike, knocked out GFCI that was on the circuit that garage door opener was on. When I ... And sometimes after it happens it takes 30 or so seconds before the opener will work again. ... The keypad unit worked well butneither the homelink or the remote units worked.
Garage Door Openers - Lightning Strike - Forum - Bob Vila
www.bobvila.com/posts/30883-garage-door-openers-lightning-strike?...
Aug 6, 2005 - The house did not lose power and I do not believe the house was actually hit. ... the light comes on on the unit (as expected), but neither door opens or ... Afterplugging it back in, try opening the door with the hardwired button first - if it still doesn'twork, chances are your opener's taken some damage but not ...
I Have A Liftmaster Garage Door Opener Unit. The Remote Work ...
www.diyforums.net/i-have-a-liftmaster-garage-door-opener-unit.-the-re.
Jan 01, 2016 | Building Materials
After a power outage, my remotes don't work. The keypad and button inside the garage work fine. I took. The batteries out for 30 seconds and unplugged the receiver too. What do I need to do?
[PDF]GARAGE DOOR OPENER Model 3265 1/2 HP ... - LiftMaster
www.liftmaster.com/.../en.../tucmanuals/114A3044.pdf Chamberlain GroupThe Chamberlain Group, Inc. 845 Larch Avenue. Elmhurst ... Please read this manualand the enclosed safety materials carefully! ? Fasten the manual near the ...
Sep 03, 2015 | Craftsman Sears Liftmaster Garage Door...
Auto garage door opens will not close not the sensors
Look at the back of the motor unit and see if that little light is flashing a code. Post the code.
Aug 13, 2012 | Sears Craftsman LiftMaster Chamberlain...
Both openers stopped working at the same time but they are both plugged in to an outlet that still has power. The lights are out on the opener wall switches. Wife thought she smelled electrical smoke when...
what openers? Sears/liftmaster of last 2 years have no reset. Sure power to outlet? Try a lamp. Did a gfi trip. Did wife run both doors to overheat them. they should cool off in 15 minutes. Do you have a surge protector. Did it go bad. Some kill power when they get cooked. Did you have a lightning storm. Culd have cooked logic boards.
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Craftsman garage door opener
Replace the logic board. I have seen this problem in the field. More often than not it's due to power surge or lightning strike.
Oct 02, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman 1/2hp Garage Door Opener
Thats one of the symptoms of a lightning strike or a power surge. Without actually being there I would suggest replacing the back-board. But as with lightning strikes and power surges sometimes other electronic components could have been damaged as well.
Jun 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
303 people viewed this question
Top Building Materials Experts
Tom Chichester
ray gallant
robert
Are you a Building Material Expert? Answer questions, earn points and help others
