Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Router installation Unable to install the router. Every time it gets to the Status Check it fails at 81%. Could it be a faulty CD. Advice please .. thanks in anticipation.
Posted by SHERR on
  • 1 more comment
  • shane28 Dec 09, 2007
    my wireless used to work but cant access 192.168.1.1 to correct my imformation
  • Anonymous Dec 23, 2007
    cd not being recognised by pc can i download instalation software
  • Mujibur Apr 18, 2008
    My modem all proper led glows, but Unable to install the router. Every time it gets to the Status Check it fails at 81%. Could it be a faulty CD. Advice please .. thanks in anticipation
Anonymous
  • 25 Answers
Hi SHERR,
Did you disable your Anti Virus, PopUp blocker, Firewall and close all other applications prior to performing the installation? Also, I would do a fresh reboot prior to doing the install. Sometimes there could be some resources still effect and those other functions can cause a conflict with the install.
--RoadHawk
Posted on Nov 25, 2007
nik parelos
  • 54 Answers
Please tell me the complete model number
When i was connected rouer the net was not working
STEP 1:Check for the light status in the router
STEP 2:Check whether you are getting the IP from the router
STEP 3:Try to install the CD that came with the router
THANKS....
With Regards......
Vaishu
Sep 26, 2010 | NetGear DG834G Router
Installation of netgear dgn2000 wireless router on vista.
I understand that you are facing trouble with the installation of the router as the CD does not work. Please perform the below steps to install the router without using CD:
1. Connect the cable/phone line coming from Internet Service Provider to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports.
3. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
4. Access the router, usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
5. Login to the router (username = admin password = password unless you have changed it).
6. Click 'setup wizard'(at the top of list) from left menu.
7. Select yes and click next.
8. It should give you a "PPPoA Detected" and then click next.
9. Enter the login and password of ISP click apply.
10. Once the settings are updated click on 'router Status' and click on 'connection status' button(at the bottom of the page).
11. Click on connect button.
12. Connecting to server should show 'connected'.
13. If you receive 'CHAP authentication failed', close the 'connection status' window and click on 'Basic settings'. Check the login and password for ISP and apply the setting again.
14. Open up another browser window and try to access internet.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jan 04, 2010 | NetGear DGN2000-100NAS Router
The only light on my router is the router light. No other lights are coming on. I have tried rebooting.
When facing the router, Globe/Internet LED is on the right. Below are the LED indicators; Check the steps below:
Wireless Security - This light will only turn on if the wireless security is enabled.
Wireless-Computer Status - This light will turn on if a wireless computer is connected to the router.
Wired-computer Status - This light will turn on if a wired computer is connected to the router. Connect the wired computer to any gray port on the router. (There are 4 gray ports).
Router Status - Power light. Solid blue means the router is on and ready.
Modem Status - If this is off, it means the router is not connected to the modem. Make sure the cable is connected from the modem to the yellow port on the router.
Internet Status - This light will indicate if the router is connected to the internet.
If this is the first time you are installing the router, then what is important is to get the router, wired-computer and modem lights ON. Once they are on, you may insert the CD that came with the Belkin router to setup the internet connection and wireless settings.
Dec 07, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
HOW CAN I USE MY NETGEAR ROUTER IF I HAVEN'T THE CD INSTALLER????
You don't need a CD installer to use it, but if you want the softwares to your router let me know the model of your router and I will send you the link to the drivers.
Sep 24, 2009 | NetGear DG834G Router
Error: 1670 Unable to load Module D:issetup.dll error code 1114
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 02, 2009 | Linksys Ultra RangePlus Wireless Routr...
NetGear WGT624 Wireless Router
No. This is referring to the free space on the CD itself. As this is a commercially stamped CD-ROM it is gonna report 0 bytes free as you are unable to add more data to the CD. The driver on the CD should install properly.
Jan 25, 2009 | NetGear WGT624 Wireless Router
Unable to load install CD
Router setup
Thanks, Joe
Dec 26, 2008 | Computers & Internet
Unable to install after 81 %
If the setup CD is unable to setup your modem/router (it is also called a "gateway") you can do the router configuration via the Web User Interface of the router. you will need ADSL settings such as:
a. Encapsulation mode. (typically PPPoA or PPPoE)
b. Multiplexing: (it can be LLC or VC)
c. Virtual Circuit Range.
d. Username & Password (ADSL UN/PW)
note: All of these ADSL settings should be provided/given to you by your ISP/ADSL provider. You can call your ISP for this settings.
just notify me if you will need further assistance doing this, but first make sure you have all the settings for ADSL.
Apr 18, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Installing Belkin Wireless G Router F5D7230uk4
No. Forget the CD and plug a computer directly into the wireless router with a ethernet cable. Open your browser and type 192.168.1.1 When a username/password box pops up type admin for username and password for the password. It should log you into the router. From there you can configure the router to detect and list your devices properly. Normally the router should be working out of the box. If admin/password doesn't work try admin/admin or admin without a password. Anymore questions with this, post here so I can help.
Jul 19, 2007 | Belkin (F6D3230-4) Router (F6D32304)
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
107 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
