Computers & Internet Logo
Sterling Silver Posted on Aug 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i use Bluetooth USB Adapter to connect PC to wireless router?I purchased a new PC that's connected to a wireless router for internet. I want to connect my old PC to the same wireless router. I don't want to run a network cable since it's far from the room where the router is, it would be too much cable. I have a Bluetooth USB Adapter and I want to know if I MoreI purchased a new PC that's connected to a wireless router for internet. I want to connect my old PC to the same wireless router. I don't want to run a network cable since it's far from the room where the router is, it would be too much cable. I have a Bluetooth USB Adapter and I want to know if I use it on my PC, would I be able to connect to the wireless router and connect wirelessly to the internet? Would this work?
Anonymous
Level 3:
President:
  • Master 828 Answers
  • Posted on Aug 03, 2009
Anonymous
Master
Level 3:
President:
Answers
828
Questions
Helped
382838
Points
3043
Bluetooth is not capable of connecting device such wireless router, only is to allow connect from Bluetooth to Bluetooth connection, but Wireless Router can detect such USB Devices which called USB Wireless LAN. You have to buy it to connect 100% on your Wireless Router. Good luck!
Anonymous
Level 3:
  • Master 1,272 Answers
Anonymous
Master
Level 3:
Answers
1272
Questions
Helped
385287
Points
3713
Hi, to connect your computer to the wireless network of the router you need to have a wireless adapter. The bluetooth adapter will not work in this case as the router does not communicate with the bluetooth signals.
Purchase a wireless adapter like NETGEAR WG111
Rate it, if it helps.
Regards
Anand
Can i use connect dongle as wireless adapter
Yes definitely ,I think i need lots more information about router version, IEEE standard.
basically adapter that uses mobile phone networks to provide broadband as a WiFi Dongle while USB WiFi adapter can be used to connect your PC to and existing wirless network provided by a wireless router.
but first you should find out what kind of Internet router you are using and always purchase a Wi-Fi adapter that is compatible with the Wi-Fi standard of your wireless router.
read more information
for more http://www.ebay.co.uk/gds/Buying-a-USB-Wi-Fi-Adapter-Dongle-Can-Make-You-More-Mobile-/10000000177329841/g.html
If you still not able to solve follow us Linksys Router Support .
I have a acer aspire 5735z and cannot connect to my new adsl modem, telstra ( internet provider) told me to ring acer, will the acer company tell me i need a new drive and will i have to pay for it??? this...
Is your Telstra/Bigpond ADSL modem has a built-in wireless router?
If the ADSL modem has a built-in wireless router and your laptop does not have a wireless card, then you have two options to connect your laptop to the ADSL wireless router/Internet -
1. Purchase a PCMCIA wireless adapter and insert it into the PCMCIA slot in your laptop. One of my favourites is made by Netgear.
or
2. Purchase a USB wireless adapter, the only disadvantage with this solution is, it uses a USB port and if your laptop has only one USB port. This is a problem if you need to connect other USB devices. Then you also need to purchase a 4 port USB hub to give you additional USB ports.
Need help with Wifi Connection with COMPAQ EVO N610C LAPTOP
First you will need a router which will enable you to create a wireless network for your internet connection. I recommend, if you're purchasing online, to use Tigerdirect. Then you would need a USB wireless adapter for your laptop which will enable it to communicate with the wireless router and establish an internet connection.
Below are some links for the most affordable and best rated products you need.
USB wireless adapter.
Wireless router
1helpful
No, I am afraid not. the bluetooth adapter will not connect to your wireless router because as of now there is no router that support that function.
you can buy a USB wireless adapter instead.
thank you for using Fixya
2answers
Recieving an invaild pointer address message when
try looking for bluetooth and make sure your phone is compatible with it
Netgear wireless adapter disconnects from router randomly
check for firmware update for your adapter...since it usb..u need to put it in open..i believed the USB extension is included when u purchased that.
do not connect the USB adapter to a USB hub unless the HUB is powered so that it can performed better. Connect it directly to your PC slot
Wireless internet
its very easy.u have to purchase a wireless router and a wireless usb adapter and isp fr internet connection,setup the wireless adapter using the cd that the company provides u with.then connect with the wireless netwrk of the router,,u wud b ready to go online
Jan 26, 2009 • Yahoo Mail
How to connect wireless router, Netgear WGR614, to my computer?
4 steps to set up your home wireless network
1.
Choose your wireless equipment
The first step is to make sure that you have the equipment you need. As you're looking for products in stores or on the Internet, you might notice that you can choose equipment that supports three different wireless networking technologies: 802.11a, 802.11b, and 802.11g. We recommend 802.11g, because it offers excellent performance and is compatible with almost everything.
Shopping list
• Broadband Internet connection
• Wireless router
• A computer with built-in wireless networking support or a wireless network adapter
A wireless router
The router converts the signals coming across your Internet connection into a wireless broadcast, sort of like a cordless phone base station. Be sure to get a wireless router, and not a wireless access point.
A wireless network adapter
Network adapters wirelessly connect your computer to your wireless router. If you have a newer computer you may already have wireless capabilities built in. If this is the case, then you will not need a wireless network adapter. If you need to purchase an adapter for a desktop computer, buy a USB wireless network adapter. If you have a laptop, buy a PC card-based network adapter. Make sure that you have one adapter for every computer on your network.
Note: To make setup easy, choose a network adapter made by the same vendor that made your wireless router. For example, if you find a good price on a Linksys router, choose a Linksys network adapter to go with it. To make shopping even easier, buy a bundle, such as those available from D-Link, Netgear, Linksys, Microsoft, and Buffalo. If you have a desktop computer, make sure that you have an available USB port to plug the wireless network adapter into. If you don't have any open USB ports, buy a hub to add additional ports.
2.
Connect your wireless router
Since you'll be temporarily disconnected from the Internet, print these instructions before you go any further.
First, locate your cable modem or DSL modem and unplug it to turn it off.
Next, connect your wireless router to your modem. Your modem should stay connected directly to the Internet. Later, after you've hooked everything up, your computer will wirelessly connect to your router, and the router will send communications through your modem to the Internet.
wireless_chart.jpg Next, connect your router to your modem:
Linksys buletooth wireless adapter
The bluetooth adapter will only work with bluetooth devices such as cell phones.  Unless you D Link router has a bluetooth transmitter on it but more than likely it has a wireless G transmitter on it.
Does your computer have a wireless G transmitter?
Usb adapter
if the router is already set up the usb dongle software will need to be used to connect to the router to allow a connection without the need for a cable as the dongle will see the wireless signal
Grand Canyon Tech
Grand Canyon Tech
