Question about Blenders
Elpine blender how does it work we have just bought and nothing is happening
Posted by David Raphael on
Blender appears to be stuck on high. Today we changed the variable speed button blender still appears to be stuck on high.
The speed control usually is by electronics. The speed control switch will merely be telling the circuitry what speed is required but if the circuitry is faulty nothing will happen.
May 13, 2016 | Vitamix 5200 VariableSpeed Blender
My Blender is not working.I can presume that it's motor have som problem...In this morning I used this blender and suddenly stopped to work....
not sure what that could be,if you have no power at all,i would first check and make sure the fuse is ok.
or try plugging it in another outlet to to make sure its not the outlet thats faulty.
Oct 26, 2017 | Brentwood Blenders
I have a Kitchen Aid 5 speed blender. After turning it on, the red light blinks, then after choosing a speed it works, but when I hit the OFF button nothing happens. I hit the PULSE button once to stop it...
Hiya,
Sorry to hear you are experiencing an issue with your blender. We believe that the described issue indicates control board fault.
If you have KSB555, please follow the link below to show you how to replace this part on your appliance.
https://www.kaparts.co.uk/Help/KitchenAidHelp/KitchenAidBlenderHelp/HowtochangetheControlBoardonaKSB555/tabid/650/Default.aspx
https://www.youtube.com/watch?v=Lafh8UGn4No
Hope you found this useful :-)
Aug 22, 2017 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
My blender died last night. I flipped the switch and the blade did not move. It was trying....but eventually stopped trying. Now nothing happens when I flip the switch. I have been using it daily for over...
:( my condolences to the blender family.Unplug it its life support and accept your loss. Gently wrap the cord around it and lay its body softly in the trash can. At least you know it tried to the very end. As you walk the isles of walmart, I feel you will find another to take its place.Good luck.
Jul 08, 2009 | Oster 4124 Beehive Work Top Blender
Kitchen Aid blender
to see if its the Triac or just the off button perform this: connect the blender,while pressing the off button press the on button; if the blender stays on and you dont hear the relay function (Light ticky sound) maybe the off button get a broken solder point. But if the relay is functioning and there is no way to change the speed the problen is the TRIAC. This is a small piece on PCB with a heat sink
Aug 30, 2008 | KitchenAid KSB3 Classic Work Top Blender
Blinking lights on KitchenAid blender
Alternating blinking lights on a Kitchenaid blender indicate a bad circuit board which is unable to run the motor properly. Unplug the blender, take the jar off, and turn the spindle by hand. Then plug it back in. If it does not work properly, try a different outlet (perhaps not in the kitchen). If nothing works, the blender needs to be repaired.
Aug 27, 2007 | KitchenAid KSB3 Classic Work Top Blender
Blenders Logo
306 people viewed this question
Top Blenders Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Blender Expert? Answer questions, earn points and help others
