Samsung HCN5529W 55in Rear Projection can't Perfect Focus
hello
What you have is a convergence problem.
There is 2 modules inside your set that aligns the colors to have the same geometry and superposed .
It is a common problem in rear projection tvs ,
You don`t have to worry about your blue tube , i`m sure it is perfectly fine, it just needs to be aligned through the convergence circuit.
Most often the problem is with those convergence modules that are faulty and need to be replaced.
Hope this will help good luck
I too can not focus the blue when I run the perfect focus function. HELP!!
