Question about Sharp Office Equipment & Supplies
How to fix service Code: C4-00 on sharp MX-B382
Posted by Arowona Lanre on
Terry
  • Sharp Master
  • 11,377 Answers
5 Related Answers
Anonymous
SOURCE: Sharp service code H5-01
To enter simulation mode to reset errors enter this sequence on keypad.
P, * , CA , P then enter sim # 14 to reset code.
press " custom settings" button to return to previous menu and CA to exit sim mode.
Posted on Dec 11, 2008
MIAN
  • 87 Answers
SOURCE: call for service: code U2-05
i think that u2 shows some memory or eeprom problem just reset it .press clear key,exposure mode key,clear key,exposure mode key,press all these key in sequence and quickly.display will go dead now press 16 then start key.code will bi removed .mian jee
Posted on Jan 21, 2009
Anonymous
  • 63 Answers
SOURCE: uc-21 code
I will have to take a stab at this at this code is not listed in the service manual. The UC codes deal with Counterfeiting! Either the user wanted to try and copy money or they copied something that had the colors very close to money so the only way to fix this is to have an authorized dealer call Sharp and have the boards ordered.
Posted on Oct 17, 2009
SOURCE: Sharp Mx-M350U shows L04-02 service code
L4 -02 cause Drum motor trouble
Improper connection of harness between the
PCU PWB and the drum motor.
Control circuit trouble
Posted on Dec 29, 2010
janalyn_glov
kuroneko4276
  • 58 Answers
SOURCE: unlock password Problems for sharp mx-2300g
Here's a link to a site that has the user manual. It's free to download, but you'll need Adobe or Nitro PDF reader to open it. I found the instructions for the same thing for my copier in its' manual. Good luck!
Posted on Aug 31, 2012
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
Error code F2-40 in Sharp mx m314n photocopier
using third party toner or drum replace toner and drum with OEM
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 04, 2015 | Sharp MX-M314N Copier
Sharp Model MXB401 Error L4-16 what is it and how do i fix it
Hello Joanne,
The error that you are receiving is due to worn gears going to the fuser assembly that need to be replaced!
The repair thread can be read at either link below:
Thread MX B401 L4 16 error
sharp mfp mx b401 error code c4 16
Good Luck!
Rich Lilja
Feb 24, 2015 | Sharp Office Equipment & Supplies
What does service code 62-05 indicate on a sharp mx 850 copier?
The best that I can do for you with tyhis question is refer you to the following link on FIXYA! ;
What does service code 62 05 indicate on sharp mx 850 copier
Dec 05, 2014 | Sharp Office Equipment & Supplies
Code L4-16
That code is for a motor lock in the fuser area. More than likely the part will have to be swapped out for a new one by a Sharp technician.
If you're in the Houston area we'd be glad to get you fixed up.
Skelton Business Equipment Houston Copiers
Aug 05, 2014 | Sharp Mx-C402sc mx-C402sc
Sharp MX 3100n showing code H5-01 , what is it,how do I fix
when your copier paper jam in fuser unit area. than show H5-01 error code.
if you fix it self,open right door and relese the jam paper carefully.
Feb 19, 2010 | Sharp MX-3501N All-In-One Printer
UC-21 code and the service manual only goes to UC-20 Model sharp MX-2300
Apr 30, 2009 | Sharp MX-2300N Color Copier
Code U2-05 call for service code!
This procedure may help, it works on older models.
Press # key
press * key
press C key
press * key
enter 16
press start key
Turn the machine off and then back on
Good luck
Apr 20, 2009 | Sharp MX-2700N Color Copier
Sharp-MX2700N Maintenance Code VK
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Feb 04, 2009 | Sharp MX-2700N Color Copier
Call for service: code U2-05
Jan 16, 2009 | Sharp MX-2700N Color Copier
338 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
