Question about The Office Equipment & Supplies
My machine shows an error fk 3 on the screen,how do i solve the fk 3 error on mx m850?
Posted by Modise Gaone on
Kenneth Simmons
  • The Master
  • 1,134 Answers
My machine sharp MX 3100N is giving the error code U2-05, what steps should i use to solve it
This error refers to a discrepancy between the HDD & the machine. If the hard drive has not been swapped out & nothing has changed on the machine then try resetting the copier to see if that rectifies it.
To reset the machine you will need to enter simulation mode.
First, make sure the copier is in COPY mode.
Then press the following 4 keys in quick succession: # * C *
You should then have a screen showing simulation mode.
Then enter 16 & press either of the copy keys (black or colour).
This should then display U2 ERROR RESET.
Press EXECUTE, YES then press the CA key.
The machine will exit simulation mode & restart.
If after restart the machine displays U2 again then you will probably have a HDD fault. Unfortunately, the HDD would have to be replaced by an authorised dealer as new Firmware would have to be reload to allow the machine to recognise a new HDD.
Hope this helps.
Dave.
Jan 19, 2017 | SHARP MX-3100N
What means E7-20 error code for sharp mx-m850
The code refers to the laser beam detection in the laser assembly.
The first thing to do is completely power the machine off & then back on to see if the machine resets. If it doesn't reset then the fault lies with the laser assembly itself & would require a technician to strip the machine to locate the problem.
Dave.
Jan 20, 2016 | Sharp Office Equipment & Supplies
We are getting a VK maintenance code on our MX-M850 copier. Does anyone know what it is and how to fix it?
This is one of the scheduled maintenance codes. it comes on at a certain "milage" and requires a technician to reset it.
If you're in Houston we'd be happy to help you out, and supply new machines should you need any.
Skelton Business Equipment Houston Copiers
Jun 19, 2014 | Sharp MX-2700N Color Copier
How I Can Solve the Code C-0540
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
May 18, 2014 | Minolta DI-2010F Copier
Need to purch a Delonghi filter kit FK22 for deep fryer typ D3 [email protected]
Hello there, the Delonghi FK 22 filter kit has apparently been discontinued by the manufacturer. Although i was able to trace a retailer who seems to have it in stock, here is the link. Although apparently the FK 4 and FK 8 and FK 6 filters could also be managed since the FK 22 is not readily available. Here are nlinks to help with them.
LINK 1
LINK 2
LINK 3
Hope this support has been helpful?
Thank you for visiting FixYa.
Sep 12, 2011 | Vacuums
My Xerox Workcentre-5020 machine showing U4 error. How can I solve this problem ?
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
Nov 07, 2010 | Cell Phones
Our printer in the office seems to stick at the top print job in the queue. we can not select it and delete it like normal. we have to turn the machine off and power it up again. it only happens when...
That very well may be the problem. The machine will tell you what is needed though.
I would suspect that the machine needs the memory flashed to correct corruption in the machine software, that sounds like the more likely cause. Not uncommon for the software to be corrupted. You will need to place a call to have a tech do that though. It is a pretty quicl call.
Jul 16, 2010 | Sharp MX-2300N Color Copier
315 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Peter March
Peter March
Level 1 Expert
Bruce Showalter
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
