The fuel mixture ratio for a 1957 Johnson 10 HP outboard motor is 50:1, meaning 50 parts gasoline to 1 part 2-stroke oil. It's important to use a high-quality, outboard-specific 2-stroke oil for lubrication, and to always mix the fuel and oil thoroughly before adding it to the fuel tank.
It's also worth noting that the fuel ratio may vary based on the specific model of the 1957 Johnson 10 HP outboard motor and the type of oil being used. It's recommended to check the owner's manual or contact the Johnson Outboard Motor company for the specific ratio recommendation for your engine.
Https://www.google.com/search?q=1957+johnson+outboard+10+hp+fuel+oil+ratio
What is the mix ratio for a Johnson outboard motor?
Any Johnson outboard motor built since 1964 requires a 50/1 fuel ratio. Motors built prior to that date require a 32/1 ratio, with the exception of a few fishing motors built prior to 1955 that use a 16/1 ratio.
Feb. 22, 2021
What is the mixing ratio for a Johnson outboard motor? - Mvorganizing.org
SOURCE: McCulloch 32cc blower, what is the fuel mixture, gas/oil
Do a 40:1 ratio to start, if it smokes cut it back alittle but 40:1 should be ok. Better to be alittle high on mix than not enough.
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
SOURCE: Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
SOURCE: Gas Oil Mixture
Fuel Mix: Add 6 oz. McCulloch custom lubricant or 1 PT. S.A.E. 40 (16:1) to 2 U.S. Gal. Regular Gas
