SOURCE: need to close google chrome to run a cleaner
If you dont see an open window of Chrome running.....go to your task manager (Right click on an empty section of your task bar and choose "start task manager"
from there go to the "Processes" Tab. in there if you see any instance of chrome.exe, click on it and click the "End Process" button
that should clear any running instances of chrome
SOURCE: i need to make google chrome my default browser
to create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options or
click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in google chrome.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search providers you
have if dont need any of them you can disable or remove them
hope this helps
