SOURCE: IM keeps logging me out.
1. Hit "run" in the start menu
2. Type "regedit"
3. Open "HKEY_CURRENT_USER\Software\Microsoft\MSNMessenger"
4. Delete the folder called MSN Messenger
5. After this MSN Messenger Live will login as normal.
or...
If you're not comfortable editing the registry, you can run this small reg. file which does the same thing as posted above:
Remove Messenger Settings
Hope this helps
Chris (ziraffa)
SOURCE: My Blackberry delete my texts and call logs automatically. Please
the trouble is that you have used all of the memory on your phone to check it go to the little tool symbol that looks like a wrench and then go to status check to see how much free files you have if it says zero you will need to delete some unwanted files most of the time its if you have a lot of ringtone or music but you can also get a memory card after you selete some files turn the phone off and take the battery out and replace it repeat the steps to see how much free files you have then
SOURCE: Cannot log out of Facebook
The solution I found is simple...
1) Go to the "Tools" option in InternetExplorer
2) Then go to "Internet Options"
3) Select the "Delete" option in the browsing history section.
4) Menu will appear, simply UNTICK THE FIRST BOX! which states "Preseve favourites website data".
This will remove the facebook cookie and stuff so when you log out of hotmail you will not see that message about not being able to log out of facebook anymore =]
Hope this helps It really should!
SOURCE: Can't log into facebook without reactivating an old account...
That is simialr to my problem and I was told by the Geek Squad that I was hacked and need facebook to help reopen my account as it is affecting even my yahoo account
SOURCE: Sorry, something went wrong. We're working on
We're working on getting this fixed as soon as we can.
when i try to log in, the same message appears the last 6 days.
i cant log in, and i have no help from facebook team.
If you'd like to delete a different account, click the username in the top-right of the Delete Your Account page, tap/click on next to username and select Log Out. Log back into the account you want to delete and follow the directions above.
