Question about American Standard Home
American Standard toilet tank won't refill. - American Standard Home
Posted by Jeremy T on
Kenneth Simmons
  • 1,183 Answers
Water turned off or fill valve bad.
Posted on Aug 29, 2018
5 Related Answers
Jim Franks
  • 374 Answers
SOURCE: tank wont refill/how to fix
JC most commonly the ball **** will hang up on the side of the tank. Take the lid off and ensure that it is in the down position. If it is not bend the rodso the ball move away from the side of the tank. If the toilet is running continously and the tank won't fill you will need to either replace the flapper valve which is in the bottom center of the tank or adjust the chain on the flapper and handle to allow the valve to open momentarily and close once the water level reaches it and drains out the hole.If all of the above did not resolve the issue you will need to replace the ballcock valve which is the piece the water supply attaches to underneath the tank on the handle side and protrudes through the tank and has the ballcock rod attached to it. The best replacement is a Fluidmaster as they are very easy to self install and easy to adjust the water level in the tank. I hope this assists you and thanks for using Fix Ya. If I can be of further assistance please let me know.
Jim
Posted on Nov 10, 2008
Anonymous
  • 35 Answers
SOURCE: I have a American Standard Carlyle, with a leak
Yes it must be cracked between the tank and bowl . Take a #2 pencil and and rub it back and forth inside the tank that should show the crack. Good Luck
Posted on Dec 02, 2009
Anonymous
  • 3085 Answers
SOURCE: Toilets are refilling between flushes
Replace the flappers, and clean around the flapper seat.
Make sure the water level is 1/2 " below the large vertical tube by either bending the float rod down or adjust the skinny silver rod on a Fluidmaster unit.
Posted on Dec 12, 2009
Larry Maranto
  • 198 Answers
SOURCE: problem: water tank running water and refilling itself
probably the flapper valve is not seating correctly over the outlet. you can fix it by reaching in and twisting the valve one way or the other till it seats properly and the leak will stop.
Posted on May 09, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: I have a american standard
To see where the water is going, place some red cake dye in the tank and see where the water turns red....this will show you exactly what is happening and where the water is going...
heatman101
Posted on Feb 22, 2011
Our American standard duel toilet takes to long to refill the tank and sometimes there is not enough water to flush just water down
Depends how old your toilet is, it may be a calcium build up problem on your little inlet pipe inside your tank, but first check your water shut off valve on left side of your toilet near the wall....It may not be open all the way OR the valve has an issue...
American Standard Carlyle Series toilet is refilling about 10 percent of the water in the tank every 20 minutes. Do I need to replace the flapper or the entire flush valve?
Start with the flapper. They tend to dry up especially with water that contains chlorine. Purchase the American Standard flapper if available for that toilet. Works better than generics.
I have a american standard cadet 111 6liter elongated toilet. I have replaced the flaper and the rubber seal in tank and I still have a problem with the toilet refilling itself after a hour or so. Any...
heatman101
We have installed an american standard duel flush toilet that uses a fluidmaster valve. Problem! The refill tube is mounted on a float attached to the overflow pipe. When the toilet is flushed the nozzle...
The overflow pipe should be attached to a small clip that holds it in position over the over flow pipe. If it is loose or attached to the outside it will do what yours is doing.
I bought a toilet from homedepot in toronto 6 months ago. from yesterday, it keeps to refill the tank like every 10 seconds. but i can not see where the water leaks
There are a few likely causes for a toilet to leak and refill. The most common is the flapper not seating properly. Usualy on an American Standard it is a disc. Either way, they are fairly easy to replace. One test I use to see if the leak is comming from the flush assembly is to put a couple drops of food coloring in the tank and wait a few minutes to see if it appears in the bowl. If so, there is a leak in the flush assembly, usualy the flapper. Hope this heps. Please vote to let me know.
1helpful
Problem: water tank running water and refilling itself
1helpful
American standard toilet
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
2helpful
Toilet tank is refilling slowly.
Hi AaronYC,
I'm Harvey the Master Plumbe.
Your problem is: Installed a new American Standard Cadet 3 toilet bowl and tank at home. When you turn the water supply on, the tank refills normally and stops normally. After you flush, the refill is very slow. When it refills normally the water comes out from the bottom of the pipe (i.e. the pipe that houses the float cup) and when it is refilling slowly, it comes from the top of the pipe. Sometimes (but not always), you can shut the water supply off and when you turn it back on, the flow of water goes from slow to fast instantly - but you haven't been able to recreate this consistently.
These are the facts. American Standard has been keeping costs down by out sourceing. Their toilets are now built in third world countries and parts are made cheap. They're all doing it. Quality control is pretty good but your toilet came with a bad "ballcock". That's the refill part on the left. Because it's new, if you take the ball **** back to place of purchase they should give you new. If not, they cost less than $ 10.00 and easy to replace.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Home Logo
Top American Standard Home Experts
Mike
john h
Ekse
Are you an American Standard Home Expert? Answer questions, earn points and help others
