SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
SOURCE: Pfaff Creative 1371
I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learn the repair skills!
Good luck.
SOURCE: pfaff 2144 presser foot lift
sounds like something has come loose or is broken, the machine needs to be serviced
SOURCE: I have a pfaff hobbylock 796.
Has any little kids been around lately? Have they had access to your sewing area and machine? (thinking perhaps the pressure foot tension has been tightened down) If it has been tightened, losen it a couple turns, see if that helps (remember, left to loosen, right to tighten)
When is the last time you oiled this machine? Typically sergers require a clean and oil each time you go to use them. Locate the bar that correlates to the presser foot add a drop of oil to the bar and let it seep in. After a few minutes try lifting the presser foot.
Also does the presser foot lever move at all?
SOURCE: The presser foot on my Janome MC9000 will not go up or down
yeah the cam lever is probably broken. Time for a new machine???
