SOURCE: wireless rechargeable mouse
might have to snc them up now to wireless reciver ok litte bottoon on bottom
SOURCE: I want to know if
You can charge it whether it's on or off. I recommend charging it while it's off.
SOURCE: My nokia 6600 when kept for charging gets charged
just change pa (power amplifier) ur problem will be 100% solved
SOURCE: lenovo mouse charging
Most of the mouses have a kind of switch and when opened, there are 2 batteries. you can replace them with other rechargeable batteries
SOURCE: rapoo mouse not working
The video is more of a physical review just in case you need someone showing you the features.
First off, have you been able to try it out on another computer anywhere, even a display in a store (disc only needed for full features, not for a test)? If the batteries were pre-installed, did you remove any plastic barrier(s) they may have placed to prevent contact? The receiver is fully seated in the USB (computer should have 'loaded' and indicated 'ready to use') and you did turn the power switch fully on? I know they may be obvious things but sometimes we all miss something obvious. If that all checks out, I hate to say it but sounds like either unit is bad or they were not properly paired at the factory (if needed). If new and still within the stores return window, return for a replacement or refund.
