Question about Midland Radio Communications
Hi I have a midland 38 and the wires have snapped in the mike plug. Can you tell me what colour wire goes to each pin in the plug so i can resolder them in please
Posted by Graham Wilkinson on
5 Related Answers
Anonymous
SOURCE: Wiring colour code
Please call 1-877-392-7247
Posted on Jan 07, 2008
Anonymous
SOURCE: Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Posted on Jan 17, 2008
Anonymous
SOURCE: wire a vga cable in backin
in vga connector their are 15 pins .u have to solve this problem u have a digital meter to cheack contunity of the pins. if there is old wire is connected on crt board .first u cheack 0 omhs continutey to 1 pin to 15th pin. then u sold ur new cable
Posted on Mar 05, 2008
Communicomm
David Eisenberg
  • 90 Answers
SOURCE: wiring a midland 78/999 cb radio microphone
Pin 1 = white
Pin 2 = shield
Pin 3 = black
Pin 4 = red
Posted on Sep 29, 2008
Anonymous
  • 367 Answers
SOURCE: kia optima 2004 transmission selector wiring colour diagram
Try this website www.kiatechinfo.com
This will be far more usefull than me just handing you the diagram
Posted on Jan 19, 2009
How do you get the cover of midland 100m mike plug...
you may have to get another plug and rewire it the same way as the one you are trying to replace. You will need a pair of wire cutters to cut the plug wire then replace it with the new one the same exact way.
Feb 07, 2016 | Midland Radio Communications
How to wire a road king 56 to a midland powe max cb radio four pin plug
one wire is ground,one wire is tx one wire is rx,so now all you have to do is find which wire goes where. do you have a multi meter? put one end into the antenna plug on the radio now put you meter on sound for an ohms reading and touch the pins .If the pin makes a loud clear sound thats your ground now the rest is trial and error. When you finally get it connected write down the wiring so you can have it at a future date.
Sep 30, 2012 | Midland 77-250CXL 40-Channels Base CB...
I have a Midland CB Car with no mike or a car power pluge, the model # is 70 - 336B and the serial # is 760408
Your midland CB will use a standard 4 pin wired CB plug which is most common for most mics sold today. Your power cord will be a standard 3 pin CB power cord which again is most common with CB's today. You need not purchase a "radio specific" cord or mic. Cobra, Uniden, Midland all the same mic pin out and power cords. Good luck.
Feb 09, 2011 | Radio Communications
The cable has been cut off of my acer monitor (v771-m) I took the back off the monitor and want to fit another cable from a different make, can someone tell me which colour wires go to which pin on the...
Have you already removed the wire from the back of the monitor or have you already replaced the wire and now want to reconnect the 15 pin D-type plug?
If its just the D-type you want to reconnect then have a look here:
http://www.monitorworld.com/faq_pages/q17_page.html
Its not the easiest diagram to follow but all you need to remember is that some wires are used and some are not.
If you dont have a particular colour of wire then it probably isnt used.
I hope that helps...
Cheers
Mike
May 12, 2009 | Acer Value V771 (White) 17 in.CRT...
I want to know how to convert my superstar121
3 Bands (LOW - MID - HIGH) 25.515 - 27.855 MHz.
Export Frequency Conversion
1. Remove the top cover from the unit and locate the PLL chip (MC145106P). Unsolder the short jumper wire running from the +8.2vdc source to pin 9 of the PLL chip. 2. 2. Resolder the three pins of the PLL chip, Pins 10, 11, and 12, being carefull not to short them together. Note: The Super Star 140 Microphone wiring is the same as all Midland Radios.
Mar 12, 2009 | Superstar SS-121 120-Channels Base CB...
Wiring a midland 78/999 cb radio microphone
Pin 1 = white
Pin 2 = shield
Pin 3 = black
Pin 4 = red
Sep 27, 2008 | Midland 1001Z 40-Channels Base CB Radio
Roger bleep kit
throw that annoying noise maker away
Jul 07, 2008 | Midland 1001Z 40-Channels Base CB Radio
Wires snapped
HI,
Sure They Can. just ensure Red To + Positive. And Black To Negative. Or If Colours are Different determine which is + Positive.
these can be resoldered on, using a standard 15-25 watt soldering iron.
Mike @ compurepair.
May 10, 2008 | Kicker S10L52 Car Speaker
Radio Communications Logo
Top Midland Radio Communications Experts
eradiostore
eradiostore
Michael Thomas
Michael Thomas
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
