Question about Andis Health & Beauty
Howto align blades 0n andis pivot pro hair clippers
Posted by Tanya Diaz on
JC Meredith
    Sergeant:
  • 168 Answers
the blade and the guard should not be parallel, they should be or look slightly out of parallel. dont forget to oil the clippers..
jm
Posted on Aug 28, 2018
5 Related Answers
heidi muehlenberg
  • 62 Answers
SOURCE: Putting blade back on my Andis dog clipper
It sounds like you may have a bent hinge which is what the blade slides onto. Please call Andis customer service at 1-800-558-9441 to speak with a customer service rep. They can give you instructions on where to purchase a new hinge or send or clippers in for repair.
Thank you,
Posted on Jul 23, 2008
Anonymous
  • 276 Answers
SOURCE: Replacement blades?
I'm not at work so can't confirm if there's blacdes for the HC920 but the majority of Remington Hair Clippers do have replacement blades.
Go to http://www.remington-products.com/country/index.htm to slect your country.
Authorised Remington Service Centers can be found at http://www.remington-products.com/consumer/asd.htm
Posted on Apr 11, 2009
Anonymous
  • 9 Answers
SOURCE: Clippers jam and won't cut when trying to use attachments
OIL THE CLIPPERS AND CLEAN THE HAIR OUT REALLY GOOD.
Posted on Jun 06, 2009
Anonymous
SOURCE: My GTO model Andis clippers
YOU HAVE TO OPEN DEM UP. TAKE OUT THE SCREWS ON THE TOP DEN TAKE OFF THE BLADE. ONCE YOU HAVE THE BLADE OUT THERE ARE TWO MORE LIL SCREWS UNSCREW THOSE (NOT ALL THE WAY OFF, JUST ENOUGH SO THAT THE BLADE WILL MOVE) ADJUST THE BLADE HOWEVER YOU WANT. IF YOU WANT IT CLOSE FOR A MORE DETAILED CLOSE LINE (NOT TO CLOSE AS DEY WILL CUT YOUR OR THE CLIENTS SKIN). YOU MUST TRY THEM OUT ON YOURSELF SEE IF THEY ARE TOO SHARP, IF THEY ARE TAKE THEM OFF AND ADJUST THEM AGAIN. EASIEST THING TOO DO IS USE A MIRROR, HOLD THE BLADE AGAINST THE MIRROR DEN MOVE IT AT AN 45 ANGLE DEN TIGHTEN THE SCREWS DER (BARBER TRICK).
Posted on Jul 21, 2009
Anonymous
SOURCE: Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Posted on Aug 23, 2009
So I have andis agc super 2 speed brand new. I have literally shaved half my dog clippers now seem too dull or cant cut hair. IThis cannot be normal to hVe this much trouble with brand new clipper
First, I'm not a Andis Tech.
* Check your warranty and call for service.
*** Following is for information only ***
* Normally I would suggest cleaning and tightening the 2 blade holder screws as in a normal "Human" hair clipper. But I noticed this pet clipper uses a snap on blade (or a combo blade as shone in "Blade Maint" video. Looks like it's mostly cleaning though I have seen other vids with clippers going dull during pet "rescues" having to trim matted hair. One lady used 2 blades and ending up using a 3d blade. It could be just that; really thick dirty hair. Dirt and grime is a collection of stone dust and oils after all.
* Demo; https://www.youtube.com/watch?v=Aun5QDCtGgc
* Blade Maint; https://www.youtube.com/watch?v=v-rS_YQ-ro0
* Basic Repair; https://www.youtube.com/watch?v=CRGEQHhfCIc
* Repair (detailed); https://www.youtube.com/watch?v=pbDLhMugSgg
Aloha, ukeboy57
Jul 06, 2018 | Andis Health & Beauty
Can I swap sharp cutting blade from one size blade to another?
Well you can either buy a new one from a local shop
http://www.angliaclipperservices.com/dog
Or wait a while and send them off for sharpening
http://www.angliaclipperservices.com/Clipper_Sharpening
May 26, 2016 | Andis Dog Clippers - AGP Super 2-Speed...
When i cut hair my andis master clipper seems to get stuck while cutting hair causing me to take longer with the fade how do i go about fixing it to where it doesnt get stuck in hair & by the way im...
mcdevito75 here, Sounds like the blades need to be sharpened, refer to the shavers brand name plus .com for blade replacement or replace the shaver.
Jun 19, 2010 | Andis 01690 Hair Trimmer
My andis t-outliner keeps pulling hair when cutting and it barley cuts the hair. Do the blades need adjusting?
sound like your clipper blades may require sharpening, just remove the blades and send them to a professional company specialising in scissor and clipper sharpening.
Jun 08, 2010 | Andis 01690 Hair Trimmer
I took apart my andis hair clippers and now i can not get the little blade to stay in place is there a trick to this?
i took apart my andis t-outliner & i dont know where to put the oval shape silver pice
May 20, 2010 | Andis 04603 Hair Trimmer
Aug 13, 2009 | Andis Health & Beauty
My clippers are running and the blades are moving but they are not cutting the hair
make sure it is cleaned and before putting it back together put a drop of clean oil between the blades. Also make sure it it adjusted properly.
Aug 04, 2009 | Andis 01690 Hair Trimmer
My andis agc2 clippers will not cut hair now.They are also a little noisy.The blades have been sharpened and are oiled.
Providing the clipper blades have been correctly sharpened try replacing the blade drive assembly which wears in width and can cause numerous problems.
Jul 04, 2009 | Andis 01690 Hair Trimmer
My GTO model Andis clippers blade is not properly aligning..how do I adjust it?
The problem with Andis clippers is that you are not told how to get the most effective job out of you're clippers,i can attest to that because i've repaired and adjusted hundreds of them,every user wants a crisp cut,nothing less, you want find the answer to that in the instructions,so you're encouraged to send the clipper back to Andis company,i did that once just to see if they really understand their own tool,the clipper cut no better upon it's return,it was then that i discoverer the ultimate solution,blades has to be precise,only then will you get a crisp cut,for any type of hair ,so before you get rid of blades,remember 85% of the time the problem is with the adjustment of the blade.
Dec 17, 2008 | Andis 01690 Hair Trimmer
Health & Beauty Logo
97 people viewed this question
Top Andis Health & Beauty Experts
Bruce Showalter
shaveroutlet.com
shaveroutlet.com
Anthony Ward
Anthony Ward
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
