Question about Kohler Home
Where do I find the serial number on my Kohler Whirlpool jetted bathtub at
Posted by Joseph grubb on
5 Related Answers
arealplumber
Better Plumbing
  • 33 Answers
SOURCE: Kohler whirlpool 5' tub
Here is the link to the Kohler 1209-LA jets exploded view:
Kohler 1209-LA
Hope this helps!
Posted on Dec 05, 2008
Anonymous
  • 21 Answers
SOURCE: We just moved into a house with a whirlpool
the bathtub needs to be full.  and you can turn the jets on some modles.  old homeowner new this and probably turned the jets up so it will do that not really funny.
Posted on Jun 25, 2009
Alan
  • 80 Answers
SOURCE: Bathtub Whirlpool button isn't working when pushed
It sounds like a bad air switch. This switch is located on the pump/motor, and is usually found at the end of a clear piece of tubing going to a box on the pump/motor, the other end of the tubing is connected to the push button on the tub. The replacement switches are avaliable through online parts companies. The best thing is to pull the pump and open the box with the switch in it. I have replaced the switch without pulling the pump/motor, but it is difficult and requires plenty of room. If you are not comfortable with doing this repair, call a reputable spa repair company.
Posted on Sep 06, 2009
Anonymous
  • 155 Answers
SOURCE: Kohler Whirlpool K-1266 (Does not star
Here are some possible causes and solutions. I know some seem simple but am trying to cover all base
  1. Jets Closed, rotate Jet trm ring counterclockwise to open.
  2. Jet not installed correctly, re-install jet, check for 'O' ring damage.
  3. Jets are blocked, Check for blockage and remove.
  4. Pump is not priming, Pumps with wooden support blocks only, Pump shimmed to high, lower pump support bracket. (wooden support blocks only)
  5. Pump is air locked. Loosen fitting on pump outlet to allow any air to escape, re-tighten.
  6. Air Actuator tubing is disconnected, loose, kinked, plugged or damaged. Connect, straighten, clean or replace air actuator tubing.
  7. Air Actuator does not work, replace the air actuator
visual check to see if pump is turning when motor is is on. If not replace the the pump you may need to disconnect the the inlet/outlet to see. I hope this helps at least provide some direction. Good Luck, Jeff
Posted on Apr 05, 2010
Freddy
  • 1311 Answers
SOURCE: I have a Jacuzzi brand
The gasket around the jet may be leaking because it is deteriorating or the flange nut on the outer side of the jet has loosened up. Check all jets for loose hardware.
Posted on Sep 12, 2010
Jets won't turn off. Pushing the button does nothing. We have to unplug it (inside skirt) to shut off jets
New? Who installed? If installer, call him back. If you did it, you missed some control wiring from main box to the controls outside or someone shorted you on some critical control parts. If you aren't sure what your doing via the owner's manual, you need a good technician. Water and Electricity don't mix and can be dangerous!.
Feb 27, 2015 | Kohler K-1224-LA-0 Mariposa 5.5 whirlpool...
I need a suction assembly biscut cover for my Kohler whirlpool bathtub with six jets
Which suction cover do you have? Can you email us a photo of the cover you have so we can match it up for you?
email to [email protected]
US Parts Center
Sep 21, 2013 | Kohler Home
Where the filter is located
There are no filters on jetted bathtubs. There is a screen with dozens of holes located in the footwell of the tub. that is the suction cover. the water flows through that screen into the front of the pump and then out through each of the water jets.
US Parts Center
Aug 21, 2013 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
Will epsom salts harm whirlpool
DO NOT use products with glycerine or oil in any Jacuzzi or whirlpool bath. It will harm the jets. Label oil or glycerine-containing gifts, "Not for Jacuzzi or whirlpool!"
If you need further help, reach me via phone at https://www.6ya.com/expert/sandra_f3927183d795a50a
May 03, 2012 | Kohler K-1110-AH-0 Purist whirlpool with...
I bought a house with aqua glass whirlpool tub (14 yrs old). Motor won't come on and I can't find reset button or serial number. Where are these items?
will have to remove access panel or make one the motor /pump assembly is mounted to the tub test for power to the switch and pump the numbers u are looking for are their by pump
May 03, 2010 | Kohler 1209-LA-0 Hourglass Whirlpool with...
How do I remove jets to clean them? I have a
Some jets are removable for cleaning and some are not. Consult Kohler about the jet removal. Normally if a jet is removable it will turn to the left (looking at the jet straight on) and then will pop with a little more force. I suggest contacting Kohler before attempting to remove the jets.
Aug 29, 2009 | Home
Kohler whirlpool will not shut off and sounds like about to blow
Sounds as if you may need a new switch to turn the tub on/off. You can find one on our site www.uspartscenter.com
Feb 28, 2009 | Kohler 1221-H-0 Seadream 6' Whirlpool Bath...
How do I install a whirlpool bathtub?
here is a link to the some installation and operating instructions.
basically you need to put a 2" x 2" runner under the lip of the tub along the three sides of the tub that touch the walls to support the lip of the tub. that pretty much covers it.
Feb 22, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Kohler 1209-LA
Hope this helps!
Nov 15, 2008 | Kohler 1209-LA-0 Hourglass Whirlpool with...
Home Logo
117 people viewed this question
Top Kohler Home Experts
john h
Bill Johnson
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
