Question about Champion Garden
I have a champion sparkplug rcj6y and rcj8 what I really need is a rcj8y shock is the best to use and will start easier?
Posted by Yosef Dov Mendlowitz on
Vernon Taylor
  • Champion Master
  • 6,701 Answers
RCJ6Y is a colder plug and might be susceptible to fouling in an engine that has a RCJ8Y recommended. The Y suffix denotes an extended nose which also tends to resist fouling and is claimed to provide a better, more positive start to the flame front. In reality there is little practical difference between the standard and extended nose plug and the performance they offer in an engine in good condition and correctly tuned.
Posted on Aug 28, 2018
Andrew Taylor
    Top Expert:
  • Champion Master
  • 33,449 Answers
Only use spark plugs recommended for the unit. Mixing or changing spark plugs is not recommend as it can cause overheating and melt the piston crown. The numbers and letters all mean something. The 'Y' if I remember correctly is extended reach, and if you put that in an engine not made for them, you will damage the crown as the flame is ignited closer to the piston crown. I did this on a Yamaha YDS3, it was an employee that suggested I used a long reach Champion plug. When the boss heard about it, I got a new piston, rings and a plug for free with his apologies.
Take the plug the manufacturer recommends and then look for equivalents in NGK or Iridium.
5 Related Answers
rycgl
Roy Cagle
  • 1545 Answers
SOURCE: The sparkplug RCJ6Y can you tell what the gap is
The gap for a similar Homelite is .025". I didn't find your exact model. I think you have the 26cc engine. Here is a user manual from similar models. Spark plug information is on page 16.
http://dl.owneriq.net/e/e795beb6-5dd6-4dbd-a82f-57b8d1a69355.pdf
You will need Adobe Reader installed on your computer to view this manual.
Posted on Oct 05, 2010
lnbn1975
  • 204 Answers
SOURCE: I have a Homelite Gas Trimmer UT21506 26cc Can you
This engine uses a Champion RCJ-6Y with .025"
(0,63mm) electrode gap. Use an exact replacement
and replace annually.
anica7ofnine
SOURCE: What is the sparkplug gap on an E4902 1969 4hp
I believe it is 30.
Posted on May 10, 2011
philwalker78
Phil Walker
  • 608 Answers
SOURCE: I want to change the
Hi, yes you can use either one. The one in it is a resistor plug which is what the "r" is. It basically reduces electrical interference with radio,s tv,s etc. Hope this helps,regards Phil.
Posted on May 25, 2011
ajvrabel
  • 97 Answers
SOURCE: what .000s is gap for
.020
Posted on Aug 28, 2011
Testimonial: "It was a Sunday afternoon and I am impressed, thanks."
What is the Gap set to on the RCJ6Y Homelite trimmer
25 thou. 0.0025
OPERATOR'S MANUAL MightyLite 26cc VersaTool String Trimmer ...
https://www.gardnerinc.com/manuals/.../Homelite/string%20trimmers/.../UT21566_96...
Your trimmer has been engineered and manufactured to our high standard for dependability, ease of operation, and ..... Mix Homelite Premium Exact Mix lubricant with gasoline .... This engine uses a Champion RCJ6Y or equivalent spark.
SOLVED: The sparkplug RCJ6Y can you tell what the gap is - Fixya
www.fixya.com/support/t6293374-sparkplug_rcj6y_tell_gap Oct 5, 2010 - The gap for a similar Homelite is .025". I didn't find your exact model. I think you have the 26cc engine. Here is a user manual from similar ... gap champion rcj6y spark plug Questions & Answers ...
Apr. 1, 2015
Weed eater spark plug gap for champion rcj6y for ...
Jun. 16, 2012
SOLVED: What .000s is gap for champion plug RCJ6Y
Aug. 28, 2011
rcj6y champion Questions & Answers (with Pictures)
Apr. 17, 2011
More results from www.fixya.com
Jun 04, 2018 | Homelite Garden
Can I use a j19lm Champion spark plug in a Featherlite series sst25 weedeater?
Hi, Check the depth of your existing plug from the screw part only & as long as the champion plug is not longer then it should be okay. Please leave me feed back: Malcolm Campbell, Thanks.
Nov 03, 2017 | Champion Garden
Is the champion spark plug RCJ8Y the same as RCJ8 ?
According to the specs on the site, the difference is one has a longer projected tip. It says that it won't HURT the machine but might result in harder to start.
Aug 13, 2017 | Champion Garden
Is a champion rcj6y spark plug the same as a champion cj6 spark plug. I have a cj6 spark plug in my blower & replaced it with a rcj6y plug & it hits the piston
You answered your in question they are definitely different..a plug hitting the piston can damage or even break the piston just trying to start the blower...replace it like the one removed..good luck
Sep 24, 2014 | Garden
Difference between rcj8y and cj8y
Hello, The only difference is the RCJ8Y is a resistor plug and the CJ8Y is not.
Jul 26, 2014 | Champion International Champion& Small...
What is the sparkplug for a Homelite SX135 Bandit?
The 25cc and 26cc engines use either a Champion RCJ6Y or an NGK BPMR7A plug.
Sep 14, 2011 | Homelite Mighty Lite Lawn Trimmer
I want to change the spark plug on my weed eater #xt300. the manual says to use champion #cj8y but the unit came with a champion #rcj8y. is it ok to use either one ?
May 25, 2011 | Garden
I have a Homelite Gas Trimmer UT21506 26cc Can you tell me the gap for sparkplug RCJ6Y Thanks
Oct 05, 2010 | Homelite Garden
Won`t start need to know plug setting and #
Here is the information you requested:
The spark plug is (Champion) RCJ6Y and it is gapped at .025"
Dec 21, 2009 | Homelite Consumer Products MightyLite...
NEED THE SPARK PLUG CHAMPION FOR POULAN MODEL 2400 CHAIN SAW
Huh? CJ8Y and RCJ8Y are SAME heat-range. Latter has internal resistor for RF noise suppression.
Nov 15, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
452 people viewed this question
Top Champion Garden Experts
Lawrence Oravetz
Vernon Taylor
john h
Are you a Champion Garden Expert? Answer questions, earn points and help others
