Question about Canon Office Equipment & Supplies
Canon PIXMA MP500 error code 6502
My grandparents have had a Canon PIXMA MP500 printer (that previously worked just fine) and I just installed it onto their new (to them) computer but error code 6502 comes up on the display every time that I turn it on. I know that they have replaced the ink cartridges and i have looked at every question that has to do with this on this website but nothing is working. Does anyone know what this error code means and how to fix it?
Posted by Ashley on
Minister Ruland
    Sergeant:
  • Canon Expert
  • 445 Answers
4 Related Answers
Anonymous
  • 18 Answers
SOURCE: Canon Pixma IP600D - error code 6502
What is the brand name and model of your printer? Make sure that your ink cartridges are precisely the correct cartridges for the brand and model that you are using. From what I have experienced ... if you try to use a used ink cartridge you will recieve an error.
Please refer to the following link http://www.coldreset.com/modules.php?name=News&file=article&sid=60
Terry
Posted on May 26, 2008
Anonymous
SOURCE: My printer won't recognise the new ink cartirdges
i think you need to buy new catridge..
Posted on May 20, 2009
Anonymous
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error massages like 6502 or other types of error message to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be released before doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled, the low ink warnings are showing again and they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be useful if you need some warranty work done on your
printer after the chips had been disabled.
Posted on Jun 10, 2009
bschilz
Bill Schilz
  • 2049 Answers
SOURCE: Canon pixma all in one mp500 error code 6A00
6A00 is a problem with the sheet feed unit.
Manually move the print head left and right, and turn the printer on/off. I would also inspect the rollers for ANY debris... it can often be fixed by using "canned air" and blowing the interior out completely.
Posted on Apr 29, 2010
I need a driver for my pixma mp500 to connect with an asus eeePC. OS says I must use one of the built in drivers, ranging from BJ... or Mutlipass C2500... , but I don't know if any of these is...
Dear Sir...
This is Ganesh from INDIA. You can download the Canon Pixma MP500 from following website address...
http://www.soft82.com/get/download/windows/canon-pixma-mp500-all-in-one-driver/
Mirror 1 for Vista ,
Mirror 2 for XP/2000.
then you just double click the file.then continue installing.(Dont fear about installing,just click,click,click)
All The Best From Ganesh A (INDIA)
Dec 04, 2010 | Canon Pixma MP500 All-In-One InkJet...
I want install my canon pixma mp500 in my [email protected]
Hi to install this device first install drivers from cd and then connect it via USB and turn on your system should find printer and install it. If you need more help let me know.
Aug 24, 2010 | Canon Pixma MP500 All-In-One InkJet...
Black line on back of paper printed by canon pixma mp500, I have tried the cleaning steps recommended by canon but it doesn't work,
You will need a shop to dismantle the printer, the ink is being forced up onto the exit rollers from below. It needs a good cleaning plus a mylar shield installed to keep that from happening again.
Dec 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500 doesn't work since I got new computer "with VISTA". Where do I go to find updated drivers that will allow compatibility with Vista?
you can download the driver for vista here http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=11995
Mar 28, 2009 | Canon Pixma MP500 All-In-One InkJet...
Scanner stopped working with new computer
Windows Vista. You now have to have the drivers for the VISTA OS . Here is your models support page to download the drivers form CANON..
Dec 31, 2008 | Canon Pixma MP500 All-In-One InkJet...
Installation - 85%
hi nan769.
you can get a fresh set of drivers from here mp500 and other support as well .
uninstall all previous drivers if dwonloading fresh drivers.
reagrds
riz.
May 12, 2008 | Canon Pixma MP500 All-In-One InkJet...
Problem installing the PIXMA MP500
INSTALL AGAIN DONT CONNECT THE PRINTER UNTILL INSTALLATION IS COMPLETE THAN CONNECT UR PRINTER
Feb 06, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500
This is the start of the fun with vista. I gives the error message "known compatibility issues" with any none MS software. It does give you the option to install anyway. Do this before plugging in the printer or vista will install it's own driver and it wont work.
the software will tell you when it is safe to plug in the printer.
you can get the vista driver @:
Jan 03, 2008 | Canon Pixma MP500 All-In-One InkJet...
Windows vista unable to install my canon pixma mp500
First download and install the latest drivers for Windows Vista. Then try connecting the printer. The latest drivers can be obtained from: www.download.com/BJ-Printer-Driver-Canon-Pixma-iP1500/3000-2116_4-10555901.html
Sep 27, 2007 | Canon Pixma MP500 All-In-One InkJet...
Open Questions:
141 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
