Question about Yamaha Electrical Supplies
What kind of oil does the Powermate 5500 yamaha MZ300 require?
Posted by Jared King on
STEVE yes that one
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Yamaha Master
  • 35,556 Answers
4 stroke engine?? syn 5w30 or straight 30w
Posted on Aug 27, 2018
5 Related Answers
Anonymous
SOURCE: coleman 5500 (MZ300)
If the oil is dirty, it will not pump properly. I recently had this problem, once I changed the oil it was good to go.
Posted on Sep 02, 2008
sal_kh_sab
sal sabea
  • 98 Answers
SOURCE: Coleman 5500 W/Yamaha MZ300 engine, runs great, no power produced
next is...brushes..
if they were fine check AVR
don't hesitate to write to me for further information:
[email protected]
Posted on Oct 16, 2009
Anonymous
  • 4 Answers
SOURCE: Have coleman powermate 5500 with yamaha engine
what won't charge the battery on the engine or what???
Posted on Oct 25, 2009
heimlich
David Belcher
  • 1978 Answers
SOURCE: what kind of oil does my 1998 yamaha tdm 850
Motorcycle oil JASO MA certified 10w-40 or 20w-50. Don't use any oil that is Energy Conserving it will shorten the life of your wet clutch and transmission gears.
Posted on Jul 30, 2010
mxc2
Marc Powers
  • 146 Answers
SOURCE: I have a powermate 5500
If the unit has a low oil shut down make sure the oil if filled to the proper full level.
If you have the proper level then you can locate the low oil shut down wire and remove the wire to test and see if the unit will run.
If the unit runs with the wire off then you either have low oil or a bad oil sending unit.
Posted on Oct 07, 2010
Yamaha mz300 throttle
It should be right their in the carb
May 04, 2013 | Electrical Supplies
PowerMate 5500 Tecumseh OHV 110 Wont turnover properly with plug in! Dealer said oil to high, drained refilled with 3/4 qt. Same symptom, good spark, good power source,valves move freely. Does this unit...
There is a centrifugally operated compression release on the cam.
They do break/come off from time to time.
Requires removal of the side (bottom ?) cover.
Feb 05, 2018 | Sport & Outdoor - Others
I need to rewind a rope on pull start powermate generator
This requires a bit of strength in the hands and the recoil will have a fair amount of tension behind it. Best have a small engine service center look at. Not expensive
Dec 19, 2009 | Coleman Powermate Generator Start &...
Engine starts and runs fine for about a minute
try to clean out the carb first with auto parts carb cleaner, then you may need to buy a totally new carb for the unit, as this company will NOT sell parts for these carbs due to the carb setting is sealed & has to stay at a set level for voltage output and setting
Nov 05, 2009 | Coleman Powermate Premium Plus 6250W...
next is...brushes..
[email protected]
Aug 29, 2009 | Coleman Powermate Premium Plus 6250W...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
132 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Robert Wooley
Robert Wooley
robert faass
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
