Check input or source
SOURCE: DVD problem - now only plays in black and white
just checked by cables and that was it! Now have color back.
I have 321
Thanks a lot!
Dave
SOURCE: DVD plays in black and white
Which type of cable are you using to connect the DVD to the TV?
Composite video - yellow RCA?
Component video - red / green / blue RCA?
S-video?
This problem could occur if you are using composite video and have it plugged into one of the component video inputs.
Alternatively it could be that you are trying to play a PAL (European DVD) source into the NTSC input.
SOURCE: sony rdr vx410 dvd player playing some dvds in black and white
SOURCE: bose lifestyle 48 dvd black and white only
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
SOURCE: DVD disks just play in black and white. No color.
This is because of the audio video format issue. You select the TV type to auto (Advisable) or to the appropriate selection such as PAL or NTSC in the DVD player to get the better output with the color.
This selection you usually find in settings > Video setup> TV Type
