Question about Casio Watches
CASIO 108 W-250. how do i reset the watch on all functions using the various buttons?
Posted by BILL BREMER on
5 Related Answers
Ekse
  • 13434 Answers
SOURCE: Casio G- Shock watch model 2943
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Posted on Jun 10, 2008
Ekse
  • 13434 Answers
SOURCE: reset casio watch wvq550dba to conserve power
Anonymous
  • 417 Answers
SOURCE: Casio Model # 2273 Sea
That Can Happen On A Low Battery Try Replacing Battery
Posted on Jul 11, 2008
Anonymous
SOURCE: casio wave ceptor WVA-105H
Casio is a great watch company
you can get online manuals anytime
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=2734&submit.x=49&submit.y=8
Posted on Nov 10, 2008
Anonymous
SOURCE: problem with casio sea-pathfinder watch
For all Casio watches go to www.casio.com select "Support" then "Manuals" then "Watches".
You will then be able to enter the 4 digit number in the square box to get the manual for your watch or module inside is actually what the instructions refer to.
The problem of changing functions automatically is called "Auto Display" and can be stopped and started in Sea-Pathfinder SPF-40 (modue 2273) by pressing the bottom left button for 3 seconds.
Posted on Nov 15, 2008
Summertime reset for casio watch stl-s100m
Go to WT(World Time) function (down-left button) ,find your actual time city and choose, by pressing the upper-left (SET) button for 2-3 seconds, between DST (Summertime) and Blank (Normal Time).
Apr 08, 2017 | Casio Watches
How to set time on my Casio Lw-200 Kids watch Its a digital watch
Thank you for contacting FixYA.<br /> <div style="BORDER-BOTTOM: medium none; TEXT-ALIGN: left; BORDER-LEFT: medium none; BACKGROUND-COLOR: transparent; COLOR: #000000; OVERFLOW: hidden; BORDER-TOP: medium none; BORDER-RIGHT: medium none; TEXT-DECORATION: none"> <li id="jsArticleStep1" itxtvisited="1"> Examine your watch. Attempt to find its "Mode" button; nearly every digital watch has one. The various modes might include "Date," "Alarm" and "Stopwatch" among others. Repeatedly press "Mode" to cycle through the modes available on your watch until you have it in the mode that displays the current time.<br /></li></div> <li id="jsArticleStep2" itxtvisited="1"> 2 Locate the button that allows you to adjust the settings on your watch; this button could be labeled "Set" or "Adjust." Once you've found this button, press it in and hold it. After a few moments, the time display should begin to flash.<br /></li> <li id="jsArticleStep3" itxtvisited="1"> 3 Select either minutes or hours as the aspect of the time you'd like to adjust. Press the "Mode" key to cycle through your options; each element should begin to flash as it's selected.<br /></li> <li id="jsArticleStep4" itxtvisited="1"> 4 Press a button to adjust the time element you've selected; the button for doing this will vary from watch to watch. If there are up and down arrows on your watch, use them to increase or decrease the number. A button labeled as another function could serve this purpose too; trying pressing the various buttons on your watch to discover the correct one to adjust the time.<br /></li> <li id="jsArticleStep5" itxtvisited="1"> 5 Move on to the next element you want to adjust, such as minutes or the date, by pressing the "Mode" display.<br /></li> <li id="jsArticleStep6" itxtvisited="1"> 6 Press the "Set" button to finalize the new time on your watch. You'll know that the time has been set when the numbers stop flashing.<br /></li> <br /> For more Casio info go to:<br /> http://www.casio.com/support/<br />Best regards.
Aug 24, 2010 | Casio LW200-1AV Wrist Watch
Casio waveceptor watch, how do i reset it
mcdevito75 here, 1 of the buttons should say MODE, press this button and see the display blinking, NOW! press the set button for each function, after each function is set press MODE to move onto the next function, when all functions are set, press MODE again to see steady display.
Jul 01, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
I live in Eastern Time Zone. My atomic clock shows map of USA in top right hand corner and it is set in Western Time Zone. How do I reset to Eastern Time Zone? I have had atomic clock for several years. I...
The "mode" button is there to change the function of the + & - buttons.
If you press the mode button several times you will cycle through the various setting features of the clock.
Look for the one that sets the time zone and use the + or - buttons to select your zone.
Some experimentation may be required!
Feb 25, 2010 | Casio GW1500A-1AV G-Shock Atomic watch
How to use the stop watch function
On Casio digital watches you need to cycle through the modes till you get to the chronograph (stop watch). Once there you can use the start stop button to start and stop the chronograph then use the reset button to set back to 00:00:00 when you need to start over.
Sep 17, 2009 | Casio Watches
Changing analog hands / time function due to daylight saving time
Download the manual from
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2747.pdf
Mar 13, 2009 | Casio DB360G-9A 30 Pages Telememo Watch
Problem with casio sea-pathfinder watch
Nov 13, 2008 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Casio Illuminator
I used the online CASIO web site to locate the appropriate manual and followed directions. Use the bottom left (C) button of the watch to keep pressing between the various modes until I was in the ALARM Mode. Then PRESS the upper right (B) button to toggle the DAILY ALARM and HOURLY CHIME to "OFF", "DAILY", "HOURLY" and "BOTH" on/off.
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1950.pdf
http://support.casio.com/manual.php?rgn=1&cid=002
Jan 17, 2008 | Casio W94HF-3AV Wrist Watch
I can't even set my Casio Marine Gear watch.
Go to this link and with the four digit module code from the back of the watch you should be able to get a manual; http://world.casio.com/wat/download/en/manual/ Hope this helps :)
Jan 15, 2007 | Casio Marine Gear MTD1042A-2AV Wrist Watch
Watches Logo
78 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Bruce Robin
Are you a Casio Watch Expert? Answer questions, earn points and help others
