Question about Hardware & Accessories
I have an old light timer model number 49550/TM151P. Could you give instructions on how to use it?
Posted by Brenda McMenemy... on
Terry
  • Hardware & A... Master
  • 11,377 Answers
Tom Chichester
    Top Expert:
  • 56,022 Answers
Google (brand)(49550/TM151P)(manual) without parens.
Posted on Aug 27, 2018
2 Related Answers
Anonymous
SOURCE: on the Noma timer Mod
1) Noma is old Intermatic brand name used by companies today to brand their timer.
2) Noma is usually associated with Woods timers.
3) Woods numbers also frequently start with 495 and with TM.
For example Woods has 49588 49556 and 78 84 29 28 62 57 33 53 65 44 68 32 77, but 49550 does not show
4) It is likely that you have a Woods brand timer.
5) Add a comment with in-focus photograph of timer for possible identification
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
6) Open following link to possibly identify timer, and then add a comment saying which timer is same-similar to yours.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Read troubleshoot section to see if your answer is there:
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Posted on Apr 23, 2011
Anonymous
SOURCE: Timer Model #: 49550/TM151P I've lost
Open following link to identify timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#49528
This Woods timer does not have replacement trippers available.
Replace with Intermatic TN311C
Posted on Jul 05, 2011
How do I set the clock? The included instructions for setting the clock do not work. I can set all the programmed on & off times, days of week, etc., everything except the friggin' clock. The cl
Give us the model number so we can see what you're talking about. Tell us what link you have tried, and how the instructions seem to be different.
Display showing no-op is sometimes associated with defective timer, bad battery. Resetting timer will clear memories and restore functionality in some cases.
http://waterheatertimer.org/How-to-troubleshoot-timers.html#digital
Attach photo of timer, or description of timer.
Add if this is new timer or if timer worked before, and what load the timer controls
Do you have correct instructions for timer ?... scan the manual into .pdf format. and then post the .pdf manual on your website .... then post link here to assist other folks with same problem.
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 11, 2014 | Hardware & Accessories
AKAI PT5598HD will not turn on.
if you got to the following link and search by the model number you will find what your looking for.
Http://www.samsungparts.com/search/search.asp
The part number for the service manual is SM-PT5598HD
As the set is showing a blinking red timer light. you can check the following link out.
http://www.techlore.com/article/15444/
May 13, 2008 | Akai PT5598HD 55" Rear Projection...
Where can we purchase Aube 7-Day Programmable 40-500w Light Timer Switch
You might be looking for T-1032 or T-1034 500watt timer
Identify model number on following link, and then google-search that specific model.
Link to instruction manual appears for each timer.
http://waterheatertimer.org/Aube-timers-and-manuals.html
Honeywell Aube in-wall timers can be used for single-pole or 3-way applications.
Look at instruction manual carefully for 3-way wiring.
Timer can be used for incandescent, halogen and CFL with minimum wattage requirement.
Since Aube timers have internal battery, they cannot be exposed to freezing temperatures or high temperatures.
Sep 28, 2011 | Aube Technologies Aube 7-Day Programmable...
I do not know how to set it. i have lost the instructions for a 111woods model tn300
Woods timers sometimes have more than one number for same timer.
This is true for most brands of timer.
Companies change model numbers and add new model numbers.
Intermatic makes two different analog timers with 111 model number. TN111 and HB111.
Grasslin has older electronic timer Tactic 111
Timex sells TE111 timer.
Open following link to identify TN300 analog timer and read instructions and download possible manual:
If TN300 is not same as your timer, view images on link and then add a comment for possible help with different timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
Open following link for instructions how to set analog timers.
http://waterheatertimer.org/How-to-set-timers.html
Sep 02, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
I have a noma 49550 and the timer let the turn on and the wheel spins as well but it doesnt shut off even with the pins and i dont know what the wheel at the top is for, is that the issue???? please help...
I don't have repair for defective timer.
The wheel at top is probably the issue. Move the wheel with your thumb and experiment with the timer.
As a general rule, the timer will not bite you.
Open following link for analog timer instructions:
My files show that 49550 is analog timer with trippers that install on timer dial.
Aug 19, 2011 | Hardware & Accessories
On the Noma timer Mod 49550/tm151p how can you tell when the switch is on
Apr 22, 2011 | Hardware & Accessories
I can not reset my Timex timer . The timer stopped working after a month and the instructions to not help in programing these timers
The instructions will help quite a lot right now:
1) Typical Timex manual says to re-set timer, press MODE and PROG buttons together.
Compare this information with your instructions.
2) Look on instruction sheet for timer model number, and then add a comment with your model number so I can identify timer manual and possibly post answer that fits your product.
3) Look on instruction sheet for company information.
Timex timers come with standard 1 year limited warranty:
Following phone might work: 1-800-919-3101
4) Scan your instruction sheet into jpg format and then add a comment with link to that jpg, then I can give you best answer for that specific timer.
5) Buy another timer, and return broken timer in new package.
6) Use circuit analyzer to test outlet for line noise and ground fault that affect timer electronics.
7) Buy another brand of timer altogether:
http://waterheatertimer.org/GE-timers-and-manuals.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 31, 2011 | Timex EASY TO SET TIMER BY TIMEX
We need clear instructions for setting the timer
Woods makes several outdoor timers:
Image that shows with this post is Woods model #49647.
Below are instructions for #49647 timer.
If your timer is different, add a comment with model number and I'll post instructions for that timer.
Woods model #49647 is outdoor timer with photoelectric control that turns timer ON at dusk.
There are 4 possible settings that show on dial.
Rotate dial to make timer selection.
OFF = timer is OFF full-time until you change dial.
ON = timer is ON full-time until you change dial.
Dusk-Dawn = timer turns ON at dusk and OFF at dawn
2, 4, 6, 8 hours = timer turns ON at dusk, and turns OFF 2, 4, 6, or 8 hours later.
Nov 26, 2010 | Woods Outdoor Lighting Timer
I am replacing an old Tork mechanical Light contoller with a new Tork digital light controller.The unit will control an outside pole light but on the same circuit I have manually switch contolled lights on...
Tork timers are each a bit different depending on voltage and model number.
Each timer has a model number on inside of timer door.
1) Add a comment with model numbers for each timer, and voltage you are working with, and I will post the conversion wiring.
2) Also look up your model number and wiring diagram on following link.
http://waterheatertimer.org/Tork-timers-and-manuals.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Nov 05, 2009 | TORK Digital Interval Timer Ssa100r-24
Hardware & Accessories Logo
694 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
