Washing Machines Logo
Question about Electrolux Washing Machines
I plug my Electrolux Top Load washing machine (EWT904TH) into a working power point. When I turn the dial to any wash program nothing appears on the display and the machine doesn't work. Any ideas?
Posted by Dan French on
5 Related Answers
Anonymous
  • 351 Answers
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
timer or timer module fault
Posted on Mar 02, 2008
Anonymous
  • 1073 Answers
SOURCE: Electrolux 1087 E90
call frigidaire for factory service or have the dealer replace it
Posted on May 09, 2008
Anonymous
SOURCE: fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Posted on May 17, 2009
Anonymous
  • 4 Answers
SOURCE: unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
Posted on Aug 19, 2009
Anonymous
SOURCE: samsung sw51asp top loader washing machine
I had the same problem and from bit of research dE probably means door error. It turns out to be the reed (magnetic) switch was not functioning properly so wasn't closing the circuit when the door is closed.
DO NOT DO THIS UNLESS YOU HAVE BASIC UNDERSTAND OF ELECTRICITY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Of you may really harm yourself.
To test if your problem is the reed switch then 1. Turn AC power OFF, unplug from wall 2. HAVE YOU TURNED THE POWER OFF? 3. Unscrew two visible screws on the back of the machine near the top 4. Take back lid off by pull up which will expose all the wires at the back 5. Put your head in the drum and look to the right under the edge you will see two wires (may be blue) connecting to a small rectangular grey unit (reed sw) 6. Follow the wires back to the back where all the wires are you will find there is a clip joiner - unplug it. 7. Use a multimeter (if you have one other wise skip to step 8) put the probes across the wires coming from the reed switch and you should find the circuit opens and closes as the washing machine lid is opened and closed. If it does not then pretty sure the reed switch is not working then follow step 8 to short it and test. 8. Another method is just to short the wires by jamming a wire across the connector that goes to the machine and NOT the connector to the reed switch This will bypass the reed switch detection so will always be a closed circuit. But since it still has a lever door open detection system it doesn't really matter.
Try a washing cycle to see if it has fixed the problem.
If you have the means then replace the broken reed switch by buying another one from your local shop.
If your problem with the dE error is not with the reed switch then it may be with the lever system which I have no experience with.
Samsun SW51ASP top loader washing machine dE error
Posted on Oct 03, 2009
Ihave Bosch Maxx 6 e2 error. I tried to reset the machine but it didn't work. What is the problem and what can I do?
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
To fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen) (and neither with mine)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
This worked for me
My Bosch max classic is showing error E2
http://www.fixya.com/support/t3342120-error_code_e2_mean_bosch_maxx
to fix you must do a master reset of the washing machine.
I have a bwm 50 washing machine displaying e2
Hope this helps
Bob
3helpful
2answers
Starts to wash and it stops and i have E 2.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
20helpful
How can I reset my electrolux washing machine afer an E20 error?
turn the dial to off. Press and hold the start pause and the nearest option button. While you're holding them down, turn the dial one notch clockwise.
The machine will beep or flash, let go of the buttons. Release the buttons, then turn the dial slowly, stopping at each click until you get to "off". Now, turn to any setting, then turn to off.
Now, try the machine. If it works, I'm very happy. If not, perhaps someone else can help.
Good Luck
72helpful
What does error code E2 mean? I have a Bosch Maxx Classic.
Electrolux 1087 E90
Zanussi aquacycle 1050 not turning on
First try another gadget, a lamp or something on the wall plug, to see if the point is live. Then check your washer plug, could be that the fuse in the plug has blown, check out your washer wire....
Top Electrolux Washing Machines Experts
David Shaub
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
