Question about NEC Computers & Internet
NEC Accusync PV46 turns on then goes black in seconds. Green light still on.
Posted by Fernando Cardenas on
2 Related Answers
vikas verma
  • 504 Answers
SOURCE: What is the fix to a TV - AccuSync PV46 that gets hot and turns off within about 5 or 10 mins.
open your monitor in on condition and see which component geting hot ok change component with new one and check it aain
Posted on May 19, 2012
Sean80000
Sean Piquet
  • 1867 Answers
SOURCE: My Lcd monitor goes black when i turn it on. NEC AccuSync lcd72vx
Sorry the unit is dead and you will need to replace it. I would avoid NEC on the next purchase.
Posted on Nov 12, 2015
Nov 12, 2015 | Computers & Internet
Tv has blue & black line on screen
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations.
Aug 04, 2014 | NEC AccuSync PV46-AVT TV
May 19, 2012 | NEC AccuSync Computers & Internet
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
No picture; power LED blinking amber/green 2-2-2-2...
You can TRY to look for cold solder at the board esp popwer section.
Apr 24, 2008 | NEC AccuSync 120 (White) 21" CRT Monitor
NEC AccuSync 120 Frequency setting
This is the maximum resolution for this monitor:
1600 x 1200 / 76 Hz
Even if you lower the resolution to the monitor, as I can see that you want to do, the maximum refresh rate is still going to be 76 Hz. If you were able to force the monitor to scan a greater field rate and its protection circuits do not shut it down, the monitor will be damaged.
Your display card is most likely limited also, unless you went out and bought a very high end card.
When using a different resolution that what the specs on the monitor indicates as its native mode, this will reduce the quality of the results displayed.
Specs for this monitor:
http://www.superwarehouse.com/NEC_AccuSync_120-BK_Black_21_CRT_Monitor/AS120-BK/ps/120193
Jerry G.
Apr 24, 2008 | NEC-Mitsubishi Nec Display Solutions...
NEC Monitor LCD1700V
I had a similar problem with a NEC LCD1935, and I traced it to the inverter board which was a Lien Chang LI-2190 ... it seems that common problems with this type of board are bad solder joints due to the temp. cycling, or blown capacitors, but I was too lazy to resolder everything so I just disconnected the BL signal line that goes between the main board and the inverter board, and this solved the problem. In my display it was a green line, marked BL on the inverter board -- I removed it from the connector and just taped it off.  I'm guessing that this is a blanking signal that the invertor uses to signal to the main board there is an overcurrent situation and that the display should be blanked/shutdown.
I'm certain that there are still problems with the inverter and it might go again, but at least I have a working monitor for the time being.
Caveat emptor.
Oct 26, 2007 | NEC AccuSync LCD71VM 17" LCD Monitor
Nec flat screen goes blank after 20 seconds
i got the same prob.supposedly its the cap(capacitor) ,the one for the power suppy near the cord input.im getting my shit fixxed.and i will let you know.
Sep 24, 2007 | NEC AccuSync LCD72VX LCD Monitor
Computers & Internet Logo
61 people viewed this question
Top NEC Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
