Question about iLO Televison & Video
I GAVE A ILO TV TO SOMEONE AND BOUGHT THEM A CLEAR STREAM #2 MAX ANTENNA . NOT A FLAT SCREEN. 28IN SCREEN 13 YRS OLD. WORKS GREAT ON CABLE. WILL THIS ANTANNA WORK ON THIS TV.
Posted by stephen gibson on
5 Related Answers
Anonymous
  • 87 Answers
SOURCE: my ilo flat screen does not seem to work with my hp computer
you need to install a driver... you can find these from the hp site or from http://www.driveragent.com
Posted on Jun 17, 2008
Anonymous
SOURCE: insignia digital tv converter/indoor antenna no signal
I had the same problem but realized that when it said NO SIGNAL,,,,it just ment for that station,,,,,switch channels and they will start to come in,,,
Good Luck,
charh20
Posted on Feb 22, 2009
Anonymous
  • 108 Answers
SOURCE: we bought vizio 32 in flat screen tv 2 yrs ago and
On the power supply circuit board some capacitors will vent (top will pop open), dome, or bulge. They can be replaced but the board is two sided and easy to damage. Having the caps replaced at a repair shop is the best way to go. If diyers try it the board can be damaged and then it would have to be replaced. Repair may cost a couple hundred dollars, but a new board can cost that alone, not including installation.
Posted on Aug 17, 2009
Anonymous
  • 47 Answers
SOURCE: Cannot hook up my genesis 2 console to my LCD tv
Hi recommend purchasing a new Mega Drive 2 Audio Video Cable found Here.
http://www.gameoz.com.au/store/sega-mega-drive/mega-drive-accessories/sega-mega-drive-2-av-cable-with-stereo-2-metres-long.html
Posted on May 07, 2010
Anonymous
  • 121 Answers
SOURCE: visio flat screen wont work with basic cable Why?
Make absolutely sure that you've selected the right inputs and have them connected properly. Many times, even with people who know what they're doing, wires end up in the wrong places and settings can get messed up.
If it's not the wiring or setup, then it's possible that that particular input is fried or otherwise messed up.
Posted on Jun 04, 2010
Hi , I would like to have Netflix installed, but I don’t own a smart TV can I still have have it installed. Thank you
I recently realized that my old flat screen had a VGA Port and a HDMI port on the back of it. Bingo! Long story short, I took an old 3.0GhZ, Win 7 Pro PC out of the closet, hooked it up to the TV with a VGA monitor cable, wireless keyboard and mouse, decent powered PC speakers, and BAM. Works great. NetFlix, YouTube, Hulu, whatever. Streams great. Not to mention PC games! Best thing I ever did with an old PC. It's just on a basic $49.95 a month Comcast router. Also, the TV has a good Digital Broadcast antenna attached to it (CBS,NBC,ABC,etc.). Just got rid of DirecTV! We watch WHATEVER WE WANT now!
Dec 13, 2017 | Smart Computers & Internet
I have a 13" flat screen TV and a clear tv antenna, the connections are different sizes, what do I need to get the tv working?
The solution may be as simple as buying an adapter, more info would be helpful. Are you hooking up a cable to screw-type antenna connection? This is the most basic adapter there is.
Feb 21, 2016 | Televison & Video
Antenna not working anymore?
talk with a tv technician as to the capabilities of the tv set but you may need a better outdoor antenna if the signal has changed from am to digital or fm in your viewing area
Jan 20, 2016 | Westinghouse Televison & Video
My Admiral color tv is 13 years old. Do circuit boards usually last that long?
most manufacturers have 5 yrs life on most pcbs so 13 is realy good
May 25, 2014 | iLO 3200 32 in. LCD Television
My reception is not crisp clear. I want to know
Are you on antenna or cable?
Some tuners do not work all that well on the TVs, if your old TV worked alot better with the same antenna then it may be a matter of using a VCR or external tuner then feeding the video into the new TV.
Cheers,
Jan 06, 2010 | Televison & Video
Tv. wont turn on
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Dec 10, 2009 | iLO 3200 32 in. LCD Television
Ilo tv trying to hook cable will not find the channels
make sure your tuner setting is in the cable mode, not antenna mode, this will lose you all channels above 13
Sep 15, 2009 | iLO 3200 32 in. LCD Television
Only channels 2-13 show on new Dynex 19" LCD TV
You'll need to find the Cable/Antenna setup and change it from Antenna to Cable. Sometimes the setting you want is called CATV.
Aug 12, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Can't get out of digital mode back into analog
My TV just did the same thing.  All you have to do is turn off the tv, unhook your cable antenna, then restart the tv with the antenna unplugged.  Then go to tv menu, and this time turn the digital scan off.  I really hoped this helped someone!
Jul 23, 2007 | iLO 2600 Television
"No Signal" on ilo-26hd
Call Dish Network at 1-888-284-7116 and they can walk you through the remote program setup. Or you can look in the instruction manual for code searching using the DN remote control.
Feb 26, 2007 | iLO 2600 Television
Televison & Video Logo
43 people viewed this question
Top iLO Televison & Video Experts
Lee Hodgson
Lee Hodgson
CoppellTVRepair.com
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
