Question about Whirlpool Microwave Ovens
How to get the defrost off, 3 squiggly lines
Whirlpool 1.1 sq.ft microwave over the range.
Posted by Carolyn Lukic on
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Whirlpool MH1170XST 1.7 Cu. Ft.
Chances are the blades are loose on the shaft or the bearings may be getting dry.
Safety & disassembly:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Posted on Dec 02, 2008
Anonymous
  • 52 Answers
SOURCE: Recommended clearance from bottom of microwave to range top
Your installation manual should have given specific height limitations. I'm not sure for your model, but I beleive it's no less than 22". If you found any of these suggestions helpful, please rate my solution. D. Lange
Posted on Apr 29, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Microwave timer counts down but doesn't turn on when started
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
Posted on Aug 30, 2009
SOURCE: Whirlpool over the range Microwave MX2155XPT-3
Either capacitor, diode, magnetron or transformer has failed. If it's the transformer there's going to be a burning smell. The rest of the parts will need to be physically accessed to diagnose. Keep in mind that these parts are HIGH VOLTAGE ~2000V and the capacitor will need to be discharged before doing anything in the high voltage compartment. There is a lot of nuances in accessing and testing the high voltage parts, so I'd suggest calling a repairman.
PS Model# does not come up.
Posted on Oct 13, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: My Whirlpool over the range microwave works but
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
xz
Posted on Sep 29, 2010
Samsung over the range microwave oven model# SMK9175ST the microwave part stopped heating
If "everything" works and your microwave just stopped heating, the problem might be with the internal door switches, the high voltage circuitry, or the circuit board or quite probalby your magnetron is dead. If you don't have the technical knowledge to repair microwaves, you should take it to a repair service for diagnostics.
Jul 16, 2015 | Samsung 1.8 Cu. Ft. Over-the-Range...
WMH32517AW Whirlpool Over-The-Range Microwave-No Fan
Go inside and check all of the connections related to the fan. Check the fuses, and the fan itself.
Nov 06, 2013 | Whirlpool WMH32517AW 1.7 cu. ft....
I cant uninstall my whirlpool microwave
The mounting bolts are usually inside the cabinet on top of the microwave. They are usually allen screws or star screws.
Jan 01, 2011 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Need install manual for my whirlpool wall mount microwave model#mh1170xsqo ser# trr1628838
At our Web site, we have a video available showing how to remove a typical over the range grille and control panel assembly in under 5 minutes.
You can download Whirlpool owner's manuals and installation instructions here.
Dec 03, 2010 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Apr 29, 2009 | Microwave Ovens
Microwave inoperative on rv generator power
Replaced with different microwave. Amanna microwave works fine on both circuits. Would not recommend Whirlpool for RV use.
Thanks
Dec 27, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Microwave Ovens Logo
Top Whirlpool Microwave Ovens Experts
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Sheldon Dedek
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
