Question about Digix HT1056A DVD
New Installation Hello Team! I just finished setting up the Digix HT-1056A DVD & Amplifyer for my husband. After several tries, I finally got the DVD player to work and all the speakers are working. My question to you all is this: Can you watch a television station through the DVD system so that it can be heard on surround sound? Please let me know as soon as your schedule permits. Thank you in advance for your prompt attention and response to this question. Respectfully,Deborah White
Posted by Deb1_White on
Anonymous
By accident i changed the video rca to composite cable and now i don"t no how to change back because is no image in the tv
Posted on Dec 10, 2007
HT-1056A. Where can I get a manual and a remote?
Try eBay or Kijiji or electronic repair shop or contact Digix..
Jun 24, 2015 | Digix Audio Players & Recorders
Rca remote code for divix HT-1056A recieer
go to www. remotecodelist.com and download for free.
God bless you
Oct 30, 2013 | RCA DRC200N
How do I finalize my disk once I have finished recording from VHS tape. How do I get the finalize to light up on menu on screen?
If they are +RW discs they cant be finalized and can only be played on +RW compatible players. Use +R, -R or -RW if you need a wider compatibility (DVD-VIDEO). Finalizing is quite easy following directions in the manual.
Apr 20, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
DVD play movies in blank and white only.
ONE OF YOUR WIRES IS PLUGGED INTO THE WRONG SLOT, PROBABLY IN THE DVD PLAYER
Apr 10, 2009 | Digix HT1056A 5.1 Channel DVD-Home Theater...
I need a manueal for digix ht1056a please
busque por internet en google en español y sale una opcion donde viene el manual y guia de este producto y ahi viene explicado todo. Gracias.
Dec 28, 2008 | Digix HT1056A 5.1 Channel DVD-Home Theater...
Dvd8723uk curtis dvd player wrong region
region code solution as per
http://www.dvdcodes.net/newCodesAZ/codesD/DigixMedia/DigixMediaHT-1056A.php
Power up the player and open the tray. With the tray open, hit the setup button and then 0000 and then the "Up" button.
On the Setup menu, go to Version and hit enter. Go to region code and change the number to 0 for region free and hit setup again to save.
Or
Press the SETUP button. The setup menu appears.
Press ZERO on the remote control four times - 0000
Press the CHAPTER FORWARD button - the one on the bottom right of the remote control unit that looks like a double arrow with a bar.
A new menu item appears, "Version". There is a REGION option you can select, and this can be set to zero "0" for all regions. Once you see its set to region 0, press SETUP to exit, close the tray and power off. When you power up again, its region free. RCE disks work fine in this unit.
To recap - open the tray, press setup, press 0-0-0-0, press Chapter Forward, select Version, choose 0 for region free, press setup again.
Or
1) Turn on the System
2) Open the tray
3) Press "setup" button
4) Press four times the number "8": 8888
5) Press the "Next Chapter" button (>>|)
6) Appear a menu called "Setup Factory"
7) Select with the cursor movement key "Region All"
8) Press "setup" button to save de changes.
Sep 09, 2008 | Digix HT1056A DVD
Fix for DVD Player
Try making DVD player multiregion
Or
Or
2) Open the tray
Aug 31, 2008 | Digix HT1056A DVD
Curtis region error
This region code solution as per
Or
Or
2) Open the tray
Aug 17, 2008 | Digix HT1056A DVD
Digix Ht-1056A Chapter Pause Problem
Tu home theater tiene karaoke integrado? Si es as?, ve al menu del aparato, dirigete al submenu audio y apaga (off) la opci?n "Semi Karaoke".
Eso deber?a de resolver tu problema ya que es com?n en algunos modelos LG con karaoke integrado.
Sep 14, 2006 | Digix HT1056A 5.1 Channel DVD-Home Theater...
Digix HT1056A DVD Logo
137 people viewed this question
Top Digix Televison & Video Experts
Vernon Taylor
ray gallant
Are you a Digix Televison and Video Expert? Answer questions, earn points and help others
