Question about Maytag Refrigerators
SOURCE: Refrigerator/ water collecting under veggie bins
sounds like you do have a clogged drain tube, its self defrosting but the defrost water is pooling under hte crispers instead of in the drain pan under unit.so you ll either have to remove hte rear panel of freezer and locate the drain trough/ tube, and defrost it allowing for water to drain down, o rclear all the tube leading down to the drain pan.
Posted on Mar 21, 2008
SOURCE: why is water forming under the veggie drawers
One of two things caused this problem, either the drain in the freezer is clogged and spilling over to the air duct and through to the refrigerator, down the back wall and then puddling up under the drawers or the Styrofoam between the freezer and refrigerator is saturated with water. If you remove the inner back wall of the freezer and there is ice built up, defrost it with hot water and a turkey baster, push some heavy weed trimmer line down the drain tube and they should clear the clog. If there is no ice build up, then you probably have the latter of the two problems, the only solution is to empty the unit, turn it off, and let it dry out for a few days with the doors opened. If the problem continues, then there is a significant breakdown of the Styrofoam between the two cavities and there isn't a solution, it is time to purchase a new unit.
Posted on Jun 16, 2009
SOURCE: Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Posted on Jul 01, 2009
SOURCE: Kitchenaid refrigerator mdl KTRS22M has water under veggie drawer
Hi, water could be excessive moisture, check door gasket, or check drain at back above veggie drawers, could be block, make sure produce not blocking drain hole, clean, check carefully for drain.
Posted on Aug 02, 2009
SOURCE: Water accumulates inside the refrigerator, Kenmore, Mod. 71194100
You get to it from the freezer. Remove the back wall in the freezer and you will see it there. Unclog it with some wire or check to see if it has ice over it.
Posted on Sep 14, 2009
May 15, 2012 | GE Refrigerators
Feb 21, 2011 | Maytag MFI2569 (249 cu ft) Bottom Freezer...
Sep 01, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Mar 08, 2010 | Frigidaire FRT21H8 Top Freezer...
Aug 15, 2009 | Refrigerators
Aug 02, 2009 | Refrigerators
Aug 02, 2009 | Kenmore Refrigerators
Jun 18, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Jun 16, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Jun 10, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
