Question about Samsung Refrigerators
Samsung cool n cool SR-L709EVSS the pc board aswell as all the sensors was replaced a few months ago. It was working fine. Until today our meat started defrosting and only the freezer temp is flickering?
SOURCE: Freezer defrosts too long.
Outside of HVACRH20 excellent advice, here a few stats about this model. The main control board will monitor the resistance of the evaporator thermistor. This is located near the top of the evaporator. This thermistor determines when the unit goes into and out of defrost. The bi-metal is redundant to the operation. It will terminate the defrost only if the thermistor fails. Check the values of the thermistor with the attached chart. Catriver..post back
Posted on Jan 28, 2007
SOURCE: samsung fridge RS2630SH, side by side, icing up on freezer.
You have to pull out the sensor from the board and test with tester, both sensor should read the resistance of 10,000 to 20,000 ohms. The reading that you show is very low it means that the thermistor is out of range and need replacement.
Posted on Mar 08, 2008
SOURCE: GE top freezer fridge forming ice on wall of freezer
Click here to see help and manuals for your refrigerator with a top freezer.
You may also be able to get parts like the defrost clock and thermostat, defrost heater element etc. as needed.
If not click-able go here by copying and pasting to your web browser.
Posted on Apr 26, 2008
SOURCE: will not go into defrost
Did you change the thermostat in heat pump? or did you change it when you replaced the board?
Posted on Dec 06, 2008
SOURCE: Refrigerator part not cooling, freezer
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 27, 2009
Jan 20, 2017 | Samsung Refrigerators
Oct 31, 2016 | Samsung Refrigerators
Nov 29, 2015 | Samsung Refrigerators
Nov 16, 2015 | Samsung Televison & Video
Jul 31, 2015 | Samsung Refrigerators
Mar 16, 2014 | Refrigerators
Jun 04, 2009 | Samsung HCM4215W 42" Rear Projection...
Jul 31, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Jun 16, 2008 | Refrigerators
Nov 21, 2019 | Samsung Refrigerators
217 people viewed this question
