Question about Power Acoustik Car Audio & Video
Why wont the bt option on my 626b power acoustik stereo open or turn on
Posted by Lisa Adame on
NEED VOLUME KNOB FOR POWER ACOUSTIK PDN-626B
Fixya does not sell replacement volume (control) knobs.
Sep 11, 2017 | Power Acoustik Car Audio & Video
What are the features?
POWER ACOUSTIK PTID-3265S CD/MP3/USB/DVD 3.2" TV STEREO SCREEN & 6.5" SPEAKERS
Mar 08, 2013 | Power Acoustik PTID-3265S
Amp has power but wont play music and its not in protect mode
Is your gain turned up on the amp????? Is you preout turned on in the settings on your stereo????? Maybe temporarily run an extra rca cable to see if thats the problem.......Are you running one sub or two????? Did the amp work before?????
Apr 13, 2012 | Power Acoustik OVN1-5500D Car Amp
I have a power acoustiks ps2-1200 it has power but the red light is on indicating that its in protection mode for some reason any idea why
There is a short or wires are touching, Then again it could be because the remote(Blue wire) From amp to stereo which tells it to turn on and off has been connected to the wrong wire and is not working effectively.
Check for any shorts check all wires from both ends it shouldn't take long and make sure no wires are even slightly touching.
Aug 11, 2010 | Power Acoustik PS2-1200 Car Audio...
Missing wire 4 from manual....whats the name of wire
just had the same problem-it does not come with the stereo or even the DTV1 box, it only comes with the NAV1 unit. Luckily I found a local stereo shop that sold me one out of ther NAV1 box since I only bought the DTV1 box with the stereo and I needed it. So hopefully you will have teh same luck , either that or you will have to buy it directly from Power Acoustik.
May 23, 2010 | Car Audio & Video
Power Acoustik LT 980-2 clipping while bridged pushing 1ohm load
Hello, your problem is that your amp is rated at 4 ohms bridged mono ans 2 ohms stereo. If your running it in stereo you need to raise the ohms to 2 ohms a channel and if your running it bridged into 1 channel you need to be running it at 4 ohms. Please rate this solution please so I can prgress on FixYa.com. Thanks!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Dec 18, 2009 | Car Audio & Video
Power acoustik gothic OV2 800 manual
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
Aug 18, 2009 | Power Acoustik GOTHIC OV2-800 Car Audio...
Play while driving
in the USA that is ilegal but if you wanted some of my colleagues put the parking cable of the stereo to ground.Good luck
Apr 03, 2009 | Power Acoustik PTID8400 Car DVD Player
Car Audio & Video Logo
54 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Professor_V
Professor_V
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
