Question about UTStarcom CDM7025 Cellular Phone
When I turn my pnone on it says DATA ABORT Ox
I lost my phone for a few weeks. When I found it and recharged it,
it would freeze in the middle of booting up. The little opening jingle would stick on a single note and the phone would continue to vibrate.
It did this for the first week now it just says the Data abort thing.
Thanks
Posted by riverdawg1 on
Andrew Taylor
    Top Expert:
  • UTStarcom Master
  • 34,081 Answers
This a 12 year old phone.
UTStarcom CDM7025 Google Search
If removing the battery and reinstalling it doesn't work, I think you need a new one. That error message doesn't appear on any searches relating to a phone.
phone DATA ABORT Ox Google Search
You could try a Hard Reset, which clears everything off the phone, although it seems to indicate, it just deletes things you have saved. One a 'normal', 'modern' phone a hard reset reloads the operating system.
UTStarcom CDM7025 User Manual Default Settings Reset Phone
Posted on Dec 09, 2017
I need help to set up my cell phone, girl yesterday wiped everything out, can you help set me back up?
If your phone has a micro SD external memore, take it out, introduce it in a USB SD Reader so it will work as a USB memory. Introcuce it in a computer and it will appear as a removable disk.
Now, use a data recover application.
A free one if RECUVA
https://www.piriform.com/recuva
Download it and install it in the computer then run it to recover the data from your SD card
Consider the content of the internal memory of your pnone lost. Sorry, no way to recover it.
Good Luck.
Recuva Undelete Unerase File and Disk Recovery Free Download
May 04, 2016 | Cell Phones
Cant make/recieve calls/texts with 2 weeks service left!
you have activated call abort
try to restore it with factory settting but before doing so backup your data and remove your memory card
Jan 26, 2014 | Straight Talk LG Optimus Zip Cell Phone
Cordless Battery-Powered Soldering Iron wont turn on anymore
You can replace the battery with other new batteries, that way, you can tell whether it is the rechargeable batteries or the iron that are faulty.
Mar 09, 2010 | Weller BP860MP Dual Heat Battery Powered...
My phone lost all of my pictures except for the one stored as wallpaper. (Very sentimental pictures of my late pet that meant a lot to me). No one has deleted them. When viewing the pictures a few weeks...
I can't assure you but there is a way to recover them, before that download free undelete.exe software from net (google). Connect the phone in DATA mode and run the undelete.exe and scan the device for deleted information if found then recover to another drive.
Hope this will be helpful
Thanks & regards
Nandu
Mar 25, 2009 | Samsung Cell Phones
Black berry Storm keeps freezing up on me
mine did the same thing, but i went into the phone and checked "NO" to the mass storage mode support. to get there....go to "options"...then click on "memory". then turn off "mass storage mode support".
Feb 26, 2009 | RIM BlackBerry Storm 9530 Smartphone
Voicemail Indicator icon
good morning to you ! i`m sure that the problem of your phone is setting ,but if you dont know to arrange the setting the best you can do is master reset your phone , but if you do that the data on your phone memory is gona be lost ,,master reset code 2945#*# thats for 2G models, 277634#*# thats for 3G models ,,,,thanks , good luck ,,,
Sep 05, 2008 | LG VX8300 Cellular Phone
Duplicacy in excel sheet
Since you are searching the data by the phone number , first select all the data in the spreadsheet and sort it in ascending order by the phone number.
Then, assuming you have 5 columns of data A through E, and the phone numbers are in column E, with row 1 occupied by column headings, use the following formula in cell F2=IF(E2=E1,"Duplicate",1)
Drag this formula down column F till the end of your data
Select the entire data and do an auto filter
In column F filter the data by Duplicate and delete all these rows
What remains should be unique data
Dec 19, 2007 | Computers & Internet
UTStarcom CDM7025 Cellular Phone Logo
101 people viewed this question
Top UTStarcom Cell Phones Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Tafi Nami
Tafi Nami
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
