Question about Blenders
I have a old national blender with glass jug ,where can get the top & bottom rubber o ring?
Posted by may loo on
5 Related Answers
Jose Mederos
  • 109 Answers
SOURCE: Replacement glass jug?
I will buy the blade set from you? I will return....
Posted on Feb 22, 2008
Anonymous
SOURCE: Kenmore KMB048 Blender
1800KENMORE
Posted on Aug 22, 2008
Anonymous
SOURCE: Any idea where we can get a new jug for a breville blender?
This happened to me recently. Go to this site and order it directly from Breville. They were very fast and customer service very helpful.
http://www.brevilleusa.com/home.do
Posted on Jan 21, 2009
Anonymous
SOURCE: I have a krups 574 blender. The male part of the
I carved off the rubber with a knife; inserted a flathead screwdriver throught the slot in the bottom to hold the gear in place; using pliers I unscrewed (COUNTERCLOCKWISE) the rubber gear.
Posted on Mar 28, 2009
Anonymous
SOURCE: Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Posted on Jul 21, 2009
Glass Jug replacement for National Blender
I have that exact same blender, and I'm missing the lid. Are you still interested in the jug?
May 14, 2014 | Sanyo 5 Piece Cord Free Collection...
Leaking from around the base of the jug
When you clean your blender there is a rubber washer in between the blades and where they sit and the glass. Try pushing the blade assembly through the bottom and locate the large washer. Peal it off carefully under warm water then either try to replace it or clean it carefully in soapy dish water. Let me know if this helps, OK?
Jud
Sep 20, 2010 | Russell Hobbs 3902US Work Top Blender
Broken glass goblet
This place has spare parts in the U.S.
http://www.abtecparts.com/index.htm
They deliver worldwide. I am in Australia and just ordered the rubber ring and on the list there was the glass jug.
Nov 02, 2009 | Krups Blenders
Krups Type Blender 577
Mine did the same thing. I am ordering a new one from America for around $5.
I am in Australia and they deliver worldwide.
Caz
Jun 12, 2008 | Krups 572 Power Xtreme VI Work Top Blender
Nov 14, 2007 | Bosch MMB2000 Work Top Blender
Blenders Logo
358 people viewed this question
Top Blenders Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Blender Expert? Answer questions, earn points and help others
