If it is inside the car in one footwell it will be one of three things. It will be either a leaking pipe to the rear windscreen washer jet, a worn door seal rubber or the heater matrix behind the dashboard.
Get into that footwell and using the back of your hand start at the floor and feel the carpet for wetness. Work your way up the carpet towards the underside of the dashboard. Your looking for the point where the carpet goes dry. Try this near the centre of the car and nearest the door. Floor only suggests washer pipe. Wet around the door is possibly a door rubber and high under the dash is most likely the heater matrix. This may seem an odd question but does the wetness have a smell? A rotten egg smell suggests screenwash. A sweet smell could be coolant.
SOURCE: water leaking
sounds like normal a/c evaporator run off,is it water or coolant,if just water,a/c,no problem
SOURCE: AIRBAG FAULT warning came on after closing
Most likely the connector on the airbag was rattled. You may need to access this and make sure its on tight. If this fails you may need to get it diagnosed. A code will further help in the direction you need to go.
Use caution as the air bag could deploy if you hit it hard enough.
To safely inspect the connector you will need to disconnect the battery for about a half hour before touching anything. This will allow the ABS module to discharge and prevent any accidental deployment.
Also be aware of any radio codes if nessasary before disconnecting the battery if needed. Also navigation could be lost if you have it.
SOURCE: VW Touran suffering from poor air circulation
First check the cabin air filter. All the air goes through this before the system. They need repacement every 15,000, or they get dirty and don't work well.
SOURCE: reset the service light on a vw touran 2005
Look in owners manual you can do this yourself very easily using ignition,milage reset button and clock reset button it's in the book cant remember which page
