Question about Acer Tablets & eReaders
Can I setup Google Home on my Acer Iconia B1-770 Tablet?
Posted by My Name on
4 Related Answers
Mister Danger
  • 5631 Answers
SOURCE: How does one enable settings to keep screen on for more than 30 seconds for the Acer a3 iconia tablet
Do a factory reset
Acer Iconia A3 A11 Recovery Boot ITFroccs hu
If still acting up, take it to repair
Posted on May 24, 2015
Gadgetgeek
  • 81 Answers
SOURCE: after pressing the reset button on my acer a200 iconia tablet it freezes on start up with only "iconic tab" showing on a black screen, what do I need to do to to restore my tablet to working order
Since you tried to reset the tablet, you can try doing the hard reset. Just to let you know, performing hard reset deletes the data from your tablet.
Iconia Tab A200 How to Perfom Hard Reset
Please let me know if it helps.
Posted on Feb 05, 2016
Lawrence Oravetz
  • 10548 Answers
SOURCE: can I install split-screen on my Acer iconia 1a810 tablet/
I don't think it has split screen capability.
Posted on Sep 10, 2016
adminmax62926
Max Desrosiers
  • 21 Answers
SOURCE: I want to know how to change the fonts on my Acer Iconia 10 B3-A30 tablet.
You cannot change the font on your system but you can change the fonts in individual applications such as browsers or ebook reading applications
Posted on Dec 31, 2016
Acer Iconia A100 tablet won't charge
Bonjour,
Peut-?tre que c'est le chargeur qui a un souci ou alors la tablette elle-m?me est d?fectueuse.Voici un lien qui devrait pouvoir vous aider.
https://www.distriphone.com/fr/127-Pieces-detachees-Acer-Iconia-Tab-A100
How to save a network password on an Acer Iconia one 7 tablet
It saves it automatically, unless you say "forget" Wi-Fi website.
Acer iconia a500 tablet freezes at the boot screen and does not go any further
The following info from
http://community.acer.com/t5/Tablets/Iconia-A500-frozen-at-Acer-logo-boot-screen/td-p/7171/page/28
might be helpful:
"How do I perform a Factory Data Reset if my Acer ICONIA TAB A500 does not boot?The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.
1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet."
Good Luck!
How to use internet in androidtab 7
Hello , with any tablet device, including Ipads, or Androids, device, check for setting and wifi setup, or if enable, or perhaps disable? if so, enable it. check for wap and secure open wifi areas
NEED SCREEN UNLOCK CODE FOR ACER ICONIA 200 TABLET
Well, the only way to unlock your tablet is to factory reset tablet.
To reset tablet start the tablet, then hold volume up then select factory reset.
1helpful
My acer iconia android tablet refuses to startup
Perform a Factory Data Reset of Acer ICONIA
The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.1.Power off the tablet.
Tablets & eReaders Logo
Top Acer Tablets & eReaders Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
NOEL
NOEL
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
