Heated fine but the next time I went to use it, it wouldn't start. If a thermal fuse, where would I find it?
SOURCE: Dryer not turning on
ok " the timer has points that act like a switch , they get burt and will not work after a long time
replace time , it's just a plug in unit
SOURCE: Kenmore electric dryer won't start
The first thing I would check would be the door switch. Dryers operate on 220 volts. Many brands split the 220v into 110v for controls and motor and 110v to the heater. There are also safety systems on many brands that won't allow the heater to come on if the fan motor is not running and blowing air throught he element to prevent overheating and dryer fires. If the door switch is ok, check the belt. If the belt is ok, it could be a problem with the motor start switch. The motor start swith is complicated fix and should be done by a professional. ALWAYS BE SURE TO DICONNECT THE POWER BEFORE ATTEMPTING ANY REPAIRS.
SOURCE: Dryer Won't Start
Make sure it has power. Then:Check the door switch.
A little lever sticking down through top right of door opening. If it is
not there you will need new door switch(sometimes the little lever
breaks off). If it is there and does not click when you press it in you
need a new door switch. if it clicks when you close the door
then you have a bad thermal fuse.The thermal fuse is found by taking
the back of the dryer off. The fuse is an oblong white plastic piece
with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
SOURCE: Kenmore Dryer-90 Series- Pushed Start button nothing happened
get a meter,unplug the dryer and read out the fuse,pull one of the wires off when you read it out,also when was the last time you cleaned out the dryer?if it's the fuse usually the air isn't moving very well,you need to clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line and make sure the outside vent is clear,if it's a long run from the back of dryer to the outside i use a leaf blower to blow out the vent line,make sure you have 240 coming in at the back of dryer,you could have a blown fuse,if the thermal fuse is good,check the thermostats on the heater box and read out the heater,good luck,if i can help with anything else let me know
