Https://www.wildlifemonitoringsolutions.nl/media/wysiwyg/manuals/Bushnell_TC_2016_ESSENTIAL_E2_manual.pdf
Unsure if this is the correct manual, but it is free to use.
https://www.wildlifemonitoringsolutions.nl/media/wysiwyg/manuals/Bushnell_TC_2016_ESSENTIAL_E2_manual.pdf
SOURCE: my bushnell trophy cam does not take pictures in
I have the same problem with mine. I am now using a higher qualith SD card and the problems seem to have resolved for now. Still testing it, however.
SOURCE: i recently purchased two Bushnell
Bushnell Trophy Cam (Trophy XLT) game cameras is not good during night time.The video images are blurry most times.Quicker object speed it causes blur.
The LED IR Flash display will light up always when you will walk by it.The sensor detects the range and when it finds any moving obstacle it take photo and in video mode flash will be ON.You miss understood the capabilities of the camera.
Thank you.
SOURCE: I HAVE A BUSHNELL TROPHY CAMERA, AND ONE OF THE
sounds like you may have scorched the connection and it's bled into the PCB, looks like you may have to get it replaced, if the batteries are at fault as in they should not have leaked then they battey firm will replace the item. check warranty terms on batts and the t/cam.
Regards
Mr Yoda
SOURCE: My Bushnell trophy Cam is
Eeeeek...4000 per day...have you changed the interval settings to 1 pic every 60 or 180 secs.
failing that..you have a real live one here...is it still under warranty?
4000 pics a day..wow..thats alot of pics.
Regards
Mr Yoda
SOURCE: My Kodak M763 says unrecognizable
Hello
The trailcam is saving the pictures in somewhat different compression or quality that the camera does not support.
I would recommend to use a Pocket Pc, a laptop or similar to view the pictures on location.
Most likely we can't change the trail cams setting or could you? What is its brand and model? do you have a manual for the trail cam that might have information about file formats?
