2 of the same fans purchased 18 months ago dim beautifully, Our electrician told us this newer one does not, because while the 2 older ones have Hallogen lights, this new one is LED. Is it possible to get these to dim the way the ones with Hallogen lights do?
SOURCE: minka aire concept II ceiling fan bulb replacement
The glass dome is tightened firmly in the factory, so removal is difficult. When removal is attempted to, the metal housing to which the dome is attached will spin with it, making removal impossible. To see what I'm talking about, look in the small space between the dome and the bottom of the blade housing - it looks like a metal flange, but this is only the bottom of the reflective metal canister that holds the light. Note that there are 4 "dimples" around the circumference of this housing, facing inward. These dimples are what hold the glass dome in place. The trick is to use a rigid piece of wood or metal about the size of a 12" ruler and place the corner of that ruler in one of those dimples - FIRMLY. Then, a second person can get some leverage on the glass dome and "unscrew" it from the housing (counter-clockwise). The purpose of holding the ruler-sized material against the dimple is to keep the housing from spinning with the dome. This is easier said than done, but it will work.
probably not the reason for the dim light. It probably has more to do with the installation where you have wired the light before or after the fan so that power so the bulb is reduced by the resistance in the fan.
lights and fans are wired in parallel so that one doesn't affect the other
Might pay to talk with an electrician on the issue
There is a limit on the size of the bulb that can be used and a 100 watt halogen bulb will probably melt the surrounds and set fire to the fitting
get a desk lamp for his homework
