Question about Furniture
Where are the capacitors on Danby DWC283BLS - Furniture
Posted by rueprt on
4 Related Answers
Dennis Boxerman
  • 1303 Answers
SOURCE: we have a danby dwc283bls wine cooler that no
that's always a possibility but not always the case. The thermostat may not be cycling correctly or set wrong. The condenser could be dirty or if there is a fan, it may not be running. Freeze ups can also cause an "Out of temp." condition. Check it out.
Posted on Apr 15, 2010
geoff hunter
  • 4793 Answers
SOURCE: Danby DWC283BLS has condensation inside the unit.
wine coolers have no means of draining the condensate inside them,use silica gel(1/2 pint)to keep the inside dry(remember to dry it out when condensate happens again)
Posted on Jul 16, 2010
taran_2005
taran_2005
  • 10515 Answers
SOURCE: My Danby DWC283BLS makes a
This means one of two things the overload relay is bad or the compressor. Pull the unit out remove the back panel there is a box on the left side of the compressor take it off and shake it if it sounds like glass is inside the relay is bad if it does not the compressor is locked up and kicking off on the overload making that noise.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
dsfgtbhrf
Jeffy
SOURCE: danby wine cooler not cooling
Take a look on amazon for parts... here: Amazon com Danby wine cooler parts. I hope this helped.
Posted on Dec 10, 2014
Fans stopped working
go to sears parts direct and enter your DWC283BLS you will have the plan and number parts you need
Mar 15, 2014 | Danby DWC283BLS Wine Cooler
F230073 p c card
try there http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000/50031952/00001?blt=06&prst=0&shdMod=DWC283BLS
Dec 16, 2013 | Danby DWC283BLS Wine Cooler
Need parts diagram for dwc283bls-1
http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000?pathTaken=&prst=0&shdMod=DWC283BLS
Dec 25, 2012 | Danby DWC283BLS Wine Cooler
How do u set temp in a Danby wine frig?
Please have a look at page 4 of the product manual where step-by-step directions are provided for setting your desired temperature.
http://www.danby.com/cms/products/en_manual/DWC283BLS_%28web%29.pdf
If you have any further questions, please do not hesitate to contact Danby Customer Service via 1-800-26-DANBY
Hours of Operation Monday -- Thursday 8:30am - 5:00pm EST
Friday 8:30am - 4:00pm EST
May 05, 2012 | Danby DWC283BLS Wine Cooler
Looking for the mother board for the DWC283BLS Wine Cooler
go at sears go to this address http://www.searspartsdirect.com/partsdirect/index.action?pop=flush
and good luck with the repair
May 15, 2011 | Danby DWC283BLS Wine Cooler
Jul 16, 2010 | Danby DWC283BLS Wine Cooler
Danby wine cooler compresser not running and is hot
The compressor needs to be tested to see if it's operational. This normally needs to be done by a service tec.
Aug 21, 2009 | Danby DWC283BLS Wine Cooler
E4 message
Disconnect the power cord from the wall outlet and wait 30 minutes before pluging back in. This should clear all settings on the cooler.
http://www.danby.ca/cms/uploads/products/en_manual/DWC283BLS.pdf
Aug 07, 2009 | Danby DWC283BLS Wine Cooler
Compressor runs and gets hot but does not cool unit
This product has been discontinued
i dont think many danby units are parts supported
more likely generic after market parts fitted by air con mechanics do the job
relay first might be a thematic one and an compressor motor fan relay
then check gas pressure
https://www.winecoolerdirect.com/danby-wine-cooler-dual-zone-dwc283bls/DWC283BLS.html
Service Manual.pdfwww.reliablepartsinc.com/danby/Manuals%20.../Service%20Manuals/DWC282%20%...
Mar 06, 2017 | Danby DWC283BLS Wine Cooler
Furniture Logo
151 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
