Question about Watches
My cookoo 2 watch isn’t turning on and I changed both batteries
How to change CR2016 and SR526SW BATTERIES OF ironman triathlon 50 lap
Timex Triathlon Ironman Watch Battery Change - YouTube
? 2:44
https://www.youtube.com/watch?v=x_C7VsE8Kks
Jun 26, 2015 - Uploaded by Lin Le
Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 ‎sr526sw
How To Change CR2016 Battery In Indiligo Timex Watch
www.mademan.com/.../how-change-cr2016-battery-indiligo-timex-watc...
Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
Nov 17, 2015 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
Casio not working
You need to Shortcut the battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs to get the watch started
Jul 29, 2013 | Casio F-91WG-9QDF F91WG 9 Digital Alarm...
I have a FOSSIL mens wristwatch model # AM3423. I recently had a watch repair person replace the battery. Battery type and charge confirmed. I received the watch used as a gift from a relative who was...
Quartz watches stop working most often for one of three reasons: (1) dead battery; (2) dirt in the gears blocking the train; and (3) a bad crystal. This is the order in which I typically troubleshoot watches.
If the watch isn't working after you change the battery, first check to see that the stem is fully pushed in. A watch movement can shift just enough inside the case that a stem sometimes looks pushed in, but isn't quite in far enough to re-engage the movement. Pull out and push in the stem a few times to see if that changes anything.
Next, assuming that the battery is indeed fine, look closely at the second hand. Is it moving at all, even a tiny bit? Hold the watch up to your ear. Is there any kind of "chunk" sound about once every second? If you can answer "yes" to either of these questions, a speck of dirt has gotten into the movement and is preventing the gears from moving freely. It doesn't take more than a a big spec of dust to cause this. Sometimes, advancing the time will move the gears enough to cause the dirt to fall out. Some watch repair places also have a special machine that spins the hands rapidly to blow out or compact any dirt in the train. It's usually not economically rational to have the movement professionally cleaned beyond this point.
Finally, if you don't hear anything coming from your watch, the battery is good, and the setting stem is pushed firmly and completely into the watch movement, you may have a bad quartz timing crystal. It does happen, and when it does, the only repair is to replace the entire watch movement. Sometimes, that's affordable; sometimes, it just doesn't make sense.
Sep 20, 2012 | Fossil AM3424 Wrist Watch
How make the hour(time )setting
Both the time and the date are set via the winding stem. To set the date, pull out the stem to the first "click" and than turn it and watch as the numbers change. To set the time, pull out to the second "click" and then turn to set the time. Some watches have a screw-down stem crown. If yours does, simply unscrew it by rotating in a counter-clockwise direction until it releases and pops out slightly.
If your watch has a day calendar function it is important to not attempt to set the hour or change the date if the current reading is between 10 PM and 2 AM. If you do, there may be some damage to the advance function responsible for moving the calendar.
The easiest way to set the time and day is to advance the date to the day before the current one. Then pull out the stem and advance the hours until the date clicks over. That is midnight and as long as the current time isn't between 10 PM and 2 AM, you're good to go.
Jul 02, 2011 | Watches
How do you get battery out of watch? Do I have to take out all screws and remove top piece?
The back of the watch has six rectangular notches around the edge. Using a jeweler's case wrench and 4-pin vise to hold the watch align the three teeth of the watch to three of the notches on the back and turn counter-clockwise. Considering that the tools alone are going to cost you a minimum of $30 - $40, and then you'll have to purchase a battery for $5 - $7, I'm going to recommend that you have the battery professionally replaced for $10 - $15 at your local jeweler. Keep in mind, I'm also considering the fact that you suggested dismantling the watch in order to change the battery. This is obviously an indication that you have no experience in the most basic servicing of a timepiece and to ensure that your timepiece isn't damaged, you really should leave this to a professional. Watch Back Example and Case Wrench captainhawk1_16.jpg
Jun 19, 2011 | Invicta 2358 Wrist Watch
Question 1:Well,this guy was gonna throw away this watch,so i asked him if i could have it.Now i have a Guess G65023G watch that doesn't work. I want to fix that. Problem 1:The minute hand turns when...
Well, thats a good watch. however, based on the conditions of your watch, probably, its battery is not dead. some of its mechanism were not in place or broken. Repairing it is advisable. Afterall it has no scratches like what you've said. So go for repair men!
Jun 09, 2011 | Guess G65023G Watch for Men
How to change battery on a ladies classic 18 k and steel watch with solid back
Welcome to Fixya,
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
5 - small screwdriver and remove/replace battery
6 - reinstall watch guts/bezel and gold screws
7 - push crown back into watch
Thank you for using Fixya.
Feb 22, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
I don't know what size battery to buy to replace the one in my Ann Kelin watch, it says Y121E
mcdevito75 Here, Your Ann Klien watch may take a 364 or 371 battery, Best Bet is to look for a small watch repair shop in your area, the $15.00 cost is worth it as you would have to remove the back of the watch then un screw the hold for the battery, your time and effort really isn"t worth it, plus the new battery will last a year maybe even longer.
Feb 09, 2011 | Watches
Seiko watch mechanism replacement
nice day to you! your watch is need of general cleaning and recondition ,efter cleaned and condition the machin ! be sure that the case back gasket is good and apply a small amount of silicon greas to avoid water damage ! close it verry tight ! good luck !god bless !
Sep 02, 2008 | Seiko Watches
Expedition Indiglo Waterproof 50m
how much is this worth my uncle gave it to me
Jan 17, 2008 | Timex Expedition 40141 Wristwatch
Watches Logo
129 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
