Question about Electrolux Dishwashers
How do you replace the control board for an Electrolux dishwasher, model no. EIDW6105GS1?
1 Related Answer
Anonymous
SOURCE: Our dishwasher model eidw6105gs1 will not start.
Think you need to reset it, leave it turned on overnight and door shut firmly, sometimes the problem is programme can not be finished from before.
Posted on Dec 01, 2010
Electrolux eidw6105gsi
Good Morning Friend,
I understand that your Electrolux dishwasher, model# EIDW6105GS1, is not cleaning your dishes. I ask that you please try the following solutions:
    1)Check the incoming water temperature. It should be at least 120 degrees F (49 degrees C).
    2)Choose another cycle for longer washing time.
    3)Check the rack loading section for proper loading-avoid nesting items.
    4)Make sure your home water pressure is not too low-it should be between 20 and 90 pounds per square inch (psi).
    5)Check water hardness. For extremely hard water, it may be necessary to install a water softener.
    6)Use fresh detergent.
    7)Make sure items are not blocking any of the spray arms, preventing them from rotating.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jun 19, 2014 | Electrolux Dishwashers
Electrolux dishwasher eidw6105gs1 No power and no
Hello Pamela, I am happy to assist you!
Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn dishwasher back. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, and faulty power supply or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Oct 03, 2013 | Electrolux EWDW6505GS Fully Integrated...
Electrolux E1DW6305GS0 error code 08
Hello ericsson1 - Typically error code E08 indicates that the control has detected a stuck or shorted key on user interface board. The wiring between main control board and user interface will need to be check by a certified professional. Depending on the diagnoses either part will need replacing. Contact a professional to move forward accurately.
Jan 06, 2013 | Electrolux EWDW6505GS Fully Integrated...
E11 code on electrolux dishwasher
You are experiencing a drain valve issue - Main Control Board timed out before receiving status of drain valve. Check wiring between Main Control Board and drain valve. If correct, replace drain valve. If error still exist, replace Main Control Board.
Aug 16, 2012 | Electrolux Dishwashers
Electrolux dishwasher error code 11
You are experiencing a drain valve issue. Main Control Board timedout before receiving status of drain valve. Check wiring between Main ControlBoard and drain valve. If correct, replace drain valve. If error still exist,replace Main Control Board.
Jul 21, 2012 | Electrolux Dishwashers
Electrolux dishwasher model #EIDW6105GS1 My dishwasher was installed one and a half years ago and has worked beautifully and quietly until recently. The last three times I have washed dishes I hear the...
turn water off....remove the dishwasher....load it into the back of your pickup truck...take it to the recyclers....go to town and buy a different unit....NOT THIS ONE...this machine will never get any better...the only good thing about it is that it looks nice.....
Aug 29, 2011 | Electrolux Dishwashers
Our dishwasher model eidw6105gs1 will not start. You push the start and nothing happens. The lights are steady.
Dec 01, 2010 | Electrolux EIDW6105GB 24 in Builtin...
Dishwashers Logo
59 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Marvin
Marvin
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
