SOURCE: electrolux epic series 3500 sr serial v87779 l
Sorry I didn't see this sooner. Your problem may be solved as simply as pushing the small red reset button exposed on top of the power head when you tilt the arm back. Very simple. Hope this helps.
John
SOURCE: the brush rotates on my dyson slim but there is no
Un-plug the machine first. Turn the unit over and remove the bottom plate. Check for and remove any debris in, around, or behind the beater bar assembly. While you're in there, look at the beater bar ends where the bearings sit. and clean any debris, hair, etc, from those areas as well.
SOURCE: Turns on, brush rotates, but no suction.
This could help you:
http://www.fixya.com/support/t2827418-very_little_suction_in_hose_no_tears_in
It worked for us.
SOURCE: my electrolux epic 6500 power
No. If the power nozzle motor is running, then a new belt will do the trick.
