Question about FUJIFILM Cameras
Fujifilm finepix HS50 EXR The screen come up with lens control error can I fix it myself
Posted by Peter Smith on
Stan Naramore
    Guru:
  • FUJIFILM Master
  • 531 Answers
  • First, reset the camera to factory default settings. On most Fuji cameras like the X100T, XT1, and XT10, you'll press MENU > Go to setup 1 (the wrench with a "1" next to it) > and then click RESET > OK. Wait 30 seconds after the reset has finished.
  • Turn the camera off
  • Next, take the battery out of the camera and leave the battery out for a FULL 2 minutes
  • Take the lens off and then replace it 3 times
  • Turn the camera back on and cross your fingers!
If not successful rub the contacts gently with the erasure of a school-type pencil
Make certain you have gone through the Menu and done a full Reset at the lowest possible level.
Make certain you are using a incompatible SDHC card instead of an SD card.
Spray some WD40 Contact cleaner onto a Qtip and gently rub the contacts.
Most often that Error Code comes up after the lens has been extended against something, i.e. the camera was turned ON when something was in front of the lens, or it was still in camera case, or the lens was jarred.
If it is malfunctioning after a mechanical insult such as being turned ON when was still in a case it may need repair.
With many cameras with a lens that extends a vacuuming of the various lens barrels will dislodge lint or other foreign bodies that are causing a Lens Error.
Posted on Aug 22, 2018
5 Related Answers
Anonymous
  • 33 Answers
SOURCE: HOW CAN I FIX MY LENS ON MY FUJIFILM FINEPIX J15?
The only thing i can think you could do is bring it to a repair shop they will repair it for free if there is warranty on it.. hope this helps
Posted on May 26, 2009
Anonymous
  • 691 Answers
SOURCE: Lens control error
Hello
Thank you for using FixYa for your problem
Sorry but the Zoom Lens has had a knock, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Dec 22, 2009
Yogesh Kshatriya
  • 1040 Answers
SOURCE: I keep getting a lens control error on my FujiFilm
Sorry Friend, it is a mechanical problem so get it serviced.......
Posted on May 08, 2010
Ty Price
  • 11967 Answers
SOURCE: FUJIFILM FINEPIX J29 has a FOCUS ERROR on the
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 13, 2010
lock123
Andrea Lock
  • 6831 Answers
SOURCE: Zoom Error for Fujifilm FinePix F480...Lens not contracting
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 07, 2010
Fuji finepix HS50 EXR lense control error, have tried default setting battery out ect, to no avail. Many thanks Martin
At this website
www.reliable-store.com I found so much of information on how to repair vehicles and technical issues in detail.. Also complete, much better language, and they also have live assistance feature
Mar 07, 2018 | Cars & Trucks
How do I solve problem lens control error?
open your cam, take out the lens unit open it, re assemble the lens.
Dec 31, 2015 | FUJIFILM FinePix F550 EXR Digital Camera
Lens control error problem. How do I solve this?
Can you give more details about the problem, please ? Many thanks.
How do i remove lens,to check & possibly replace lens cover.
By carefully dismantling the camera
Take a look at YouTube to see how to dismantle compact cameras and decide if you are happy to give it a go
Jul 15, 2015 | Fujifilm FinePix F660EXR 16MP EXR CMOS...
Marks on inside of lens
If lens was cleaned properly, you may have dirt on sensor.
Feb 27, 2014 | FUJIFILM FinePix F550 EXR Digital Camera
Showing lens control error fuji finefix HS 30 exr
Does it say Lens control error, or does it say Focus error, turn off the camera and turn it on again?
The last can happen when you touch the lens barrel. When the lens does not retract when you shut down the camera, perhaps the battery is exhausted or the barrel got stuck.
Try to recharge the battery and start all over again. If nothing goes, try carefully to pull out the lens a little Less then one millimetre. or gently press it back a little. Be aware the camera is a very delicate piece of equipment, so don't use force, because that could damage the camera definitive.
In the manual, it says you should contact FujiFilm, when the error comes back after you switched off and on. So if nothing helps, that is the last option. Visit a repair shop from Fuji, or bring a visit to your dealer.
Dec 27, 2013 | FUJIFILM FinePix F300EXR Digital Camera
Fujifilm Finepix HS25 EXR screen replacement
Your best bet is going to be E-Bay, search your camera make and model under parts and you will find just what you are looking for.
Jan 23, 2013 | Fujifilm FinePix HS25 EXR 16MP, 1080p 30X...
I recently purchased a Fujifilm Finepix Hs20EXR Camera. Is the zoom lens removable and if so, how do you remove it?
The lens is NOT removable. It's a Bridge camera. If you did manage to remove it, you'd break the seal and allow dust, etc into the camera body. Besides, you cannot fit a different lens anyway, so why bother?
eVAPor8
Jan 06, 2012 | FUJIFILM HS20 EXR Digital Camera
Cameras Logo
258 people viewed this question
Top FUJIFILM Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Falling star
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
