Question about Polycom Lands Phones
Polycom vtx shows incoming call and when picked up i only hear my voice what could be the issue?
Posted by Kyle Kamanga on
5 Related Answers
fleshgear
Avinash Raj
  • 541 Answers
SOURCE: I CANNOT HEAR THE INCOMING CALL VOICE
problem with speaker contact service center
Posted on May 28, 2009
Anonymous
  • 151 Answers
SOURCE: NOKIA 1600 I CAN HEAR THE VOICE WHILE THE OTHER
Your MICROPHONE is not working.Please get it replaced
Posted on Aug 25, 2009
Anonymous
  • 1049 Answers
SOURCE: Static from SoundStation Premier
Check the phone cable you are using for your POTS line. Attach a phone directly to the phone jack and see if it is clear or static without the device.
Posted on Oct 01, 2009
rileyw
  • 30 Answers
SOURCE: I can't hear incoming call
During a call, you can adjust the volume as you normally would, using the + and - buttons on the side.
Posted on May 04, 2011
intower18
Eury Satorre
  • 957 Answers
SOURCE: Polycom soundstation 2 not showing
The link below may help you on resolving the issue. This is a PDF file for user guide:
http://www.orficn.net/Verizon%20Website/Phone %20Manuals/audio_conferencing_polycom_soundstation2_user_manual.pdf
Just click it. Please let me know if this help you or not so that I will proceed to the other solution.
Posted on Jul 23, 2011
I can't hear the other person's voice in incoming calls to my cellphone.
Maysie, This is a Speaker problem (hardware problem), show some official repairer to change or fix it, but temporary you can use headphone or Bluetooth to communicate by your device. Best of Luck.
Jul 12, 2012 | Cell Phones
Hi, I have Ploycom QDX6000 and facing two problems. Please let me know if you can help me to fix the same 1- I can not pick the call is someon calls but i can dial out successfuly 2- Fan-end camera...
1) try setting unit to auto answer and it will automatically pick up incoming call
2) far end will only control a Polycom camera and it will not work through a bridged call - it must be point to point
hope this helps you
good luck!!
Mar 31, 2011 | Polycom QDX 6000 (720030831001) Video...
We moved our Polycom Soundstation 2 from one office to another. It was disassembled and reassembled by who knows who. It is using an analog port from an NEC DSX 80. It recognizes an incoming call, but,...
sounds like the 'brick' went bad
this is the power supply try replacing it
also and possibly more important did you reprogram phone and phone number when you moved it??
make sure you reset all settings and start new
Mar 17, 2011 | Polycom SoundStation
Incoming audio fails from remote location
hi
as u mentioned, (firewall), when u do this the audio packets get blocked, u need to open the audio ports or best is to go for a dedicated bandwith only menat for the VC so there is no security issue & u can use the VC much comfortably
Dec 21, 2008 | Polycom VSX 7000 Video Conference
Extension Mics on the Polycom Audio Conference Phone SS2W/EX are very faint
Please I have the same issue, the receiver cannot hear whjat we are saying our voice is very faint to the receiver as if we are calling from a very far distant location from the phone.
Aug 08, 2008 | Polycom SoundStation 2W (2200-07800-001)...
May 20, 2008 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
For incoming calls, the caller cannot hear me for 2-10 seconds after I pick up
You've got an IP issue somewhere in your setup. It sounds like the call is being lost and then the phone is querying the DNS server to find out where it should be looking for the call. Do you have a VOIP server name or it's IP address in the setup? Are you using DHCP or manually assigning IP addresses? If the VOIP server is not on a static IP, I would fix that first. Post back here the answers and we can look at it further.
Aug 04, 2006 | Polycom SoundPoint IP 501 IP Phone
Lands Phones Logo
62 people viewed this question
Top Polycom Lands Phones Experts
pbxinc
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
