Question about Adidas Watches
Adidas ADH4041 after install new CR2025 battery how to reset with tweezers. I see RST on pc board but press what?
Posted by Mike Schmidt on
Hour, minute and second hands don't work, why?
Yes, there are two batteries in the 19093 (Compendium Hybrid). The first battery (CR2025) is visible as soon as you remove the back cover plate. The CR2025 controls the digital half of the watch and the back light. The second battery is underneath the circuit board that the CR2025 is connected to. There are 6 small screws that will need to be removed to lift the circuit board and gain access to the second battery. The second battery is an SR626SW.
Aug 22, 2014 | Watches
Just changed the battery in my Adidas ADP1426, now the screen just displays "230" and none of the buttons do anything....? What do I need to do to get it back up and running?
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs.
Jul 15, 2013 | Watches
Set after new battery installed
If you take a jeweler's lupe near where the arrow is you will see the word "reset" in the plastic.
There is a deep hole in the plastic with contacts below. That is the reset, and that is why you must use very sharp pointed tweezers to make contact with the back of the battery.
I think if you do not have sharp tweezers, you can probably put a sewing pin down the hole, and then connect with a small screwdriver to the back of the battery
Aug 20, 2012 | Casio WVQ560A-1AV Wave Ceptor Watches...
My adidas adp1426 watch had a new battery put in and not none of the side buttons work, the only response i get is when I hold all four down at once it resets but continues to have the same problem, any...
Thank you for contacting FixYa.<br /> Did you do the battery yourself or have a repair service center do for you??<br /> It could be that the buttons are not making the correct contact or that it needs to be reset.<br /> I would take back to service center and see it they can correct. If needed, you can also contact Adidas at :<br /> <a href="http://www.adidas.com/us/shared/help/help_contact-us.asp">http://www.adidas.com/us/shared/help/help_contact-us.asp</a>
Aug 25, 2010 | Watches
The battery of my XG-55 is down. I tried with several watch repair labs, but they told me that after changing the battery, the watch doesn't start again. Any advice?
When you change the battery on this watch you have to short the circuit board. You need a fine pair of tweezers and you need to look on the circuit board for an arrow or bare spot, put 1 end of the tweezers on that place on the circuit board and the other on the battery at the same time. that should do the trick if the battery was installed correctly and the battery is good.
Nov 18, 2009 | La Crosse XG-55 Wrist Watch
Having fitted a new battery I need to re-set a Crane & Viceroy atomic watch but cannot find the re-set button.
The reset is typically not a button. If you look at the back lid with the watch open you might have instructions to reset or "AC" the watch. Usually this involves using tweezers or lever to contact the battery and circuit board to clear it. My suggestion for this procedure is to see a watch maker/technician since the circuit board is easily damaged.
Sep 15, 2009 | Watches
Start buttons don't work after battery change Adidas Sports Timer
You will have to open your watch, because the contacts or contact springs are not stiff enough, so, you need to make them stiffer.
Do as follows:
1) Open your watch caseback
2) Extract the movement (carefully and using tweezers), do not touch dial with fingers,
3)Take small brush and lighter fluid (ZIPPO) and clean all pushbuttons in case from inside and out pushing them rapidly, then use dust blower to dry the fluid out,
4)On the movement you will see contacts corresponding to each pushbutton on the case. Use needle or sharp metal pin to clean (scrape) off any visible residue from these contacts till they are shiny.
5)Pull all contacts on movement sligtly outwards using tweezers but be careful not to brake. This will make them stiffer.
6)Reassemble the watch and the problem should be sorted.
Do not forget to rate, please.
Aug 14, 2009 | Watches
Battery change and then reset
If you open already the watch,and you want to take the old battery,there is a clip that's lock the battery twist that lock.then the battery comes out and replaced with a new one. If you have already put the battery and no display you must reset it by shorting battery connection,in the plate there is arrow guide to the hole where you put your tweezers to short the connection.then the display appears 8888,that is already resetted take the tweezers..
click below for video guide;
G-ShockBattery Change Tutorial
hope this may help
DON'T FORGET TO RATE
Regards,
VOTIT
Jul 29, 2008 | Adidas Watches
Setting the date
If not in the time mode, press mode to get to the time mode.
While in the time mode, press and holdlap/rst for two seconds.
The seconds will begin to blink.
Press st/stop to reset seconds to zero
Press mode and the minutes will begin to blink.
Press st/stop to advance the minutes
Press mode and the hour will begin to blink.
Press st/stop to advance the hour
Press mode and the day and date will appear. The day will blink.
Press st/stop to advance the day.
Press mode and the month will begin to blink.
Press st/stop to month the minutes.
Press lap/rst to return to normal state with you new settings. You can hit lap/rst to return to normal state at any time in the process, for example if you only want to set the minutes, just hit lap/rst after you set the minutes.
Apr 28, 2007 | Timex 1440 Nylon watch
Watches Logo
111 people viewed this question
Top Adidas Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
ray gallant
Are you an Adidas Watch Expert? Answer questions, earn points and help others
