Unplug 950 from wall display reads 10 then starts to drop- battery holds a little charge even after several hours charging light very dim but it does come on when selected.
SOURCE: Battery is Being Drained in 1996 Chrysler LHS
I’m having this same problem on my 99 LHS, I’ve been told that it’s caused the body control module. Maybe a bad ground?
SOURCE: The battery light came on my trailblazer.
You need to have the charging system tested before your vehicle leaves you stranded. The battery could be the victim.
SOURCE: cadillac escalade ext will not start dic message
A battery can read 12 volts yet be weak in cold cranking amps, try a jumpstart and if that works have your battery load tested. Im betting your gonna find the battery fails the load test, meaning it needs to be replaced..
SOURCE: no power to anything - how do I reset anti-theft
no... no power to anything means like the headlights are inop and such
in that case its a battery or battery cable issue
assuming you have headlights and power to accessories and the vehicle still will not start AND the theft light is flashing then YES your anti-theft system is trying to keep the car from what it thinks is a theft issue
simply pressing the unlock button on your remotes will resolve this
assuming you do not have the remotes then you will need the anti-theft computers reprogrammed at a dealer or good garage
keep us posted
SOURCE: Won't hold a charge
Sounds like good answers...most likely the battery has a bad cell...you can get a free test at most parts stores...(Take your jumper cables with you, so you won't be stranded...Hope this helps.
