SOURCE: lost drivers cd
Go to:
http://www.lge.com/support/software.jsp
using Internet Explorer (I tried Firefox and Opera, neither work well)
Select your location and country. Then choose Notebook, your rd400 series, and your operating system.
When I did it, the "Onboard LAN Driver" was on the second page of results.
As far as your acer, go to this site:
http://www.acerpanam.com/synapse/forms/acerdrivers.cfm
select your model from the list and download the .pdf file with links to all the drivers for that model.
Cheers!
SOURCE: Toshiba R100 keyboard not working
I did the same some two years ago, with the R100 on. I switched everything off, dismounted the computer body (not the screen)up to the last screw, and dried that sweet coffee from everywhere where I found it. Mostly this was the keyboard and mouse. The motherboard is luckily protected by some plastic sheet.
Regarding the keyboard, after disconnecting it from the motherboard, I washed it completely under flowing water and then let it dry for several days. In the meantime, I used a USB one. Since then, I used the same keyboard for two years until now, when it died, apparently rather from some motherboard-related reason than water. So I think - you may get a new keyboard, but if youre lucky, you may as well revive this old one.
SOURCE: I need a replacement keyboard for Medion laptop
Check first for a spare on Ebay, that will be cheaper than buying a new spare, but parts for this model are difficult to find.
For example here is a RAM2000 keyboard, contact Medion to find out if it is compatible:Cybercom MD42792 Medion Ram2000 Replacement Keyboard
If you do not find a compatible part, call medion, they can supply parts and tell you what parts are compatible:Medion.com
Try also Computer parts for MEDION
In US you can also contact Quanta that distributes medion parts internationally, they are locaed in US and ask part price and availability: Contact Us
