Question about Zanussi Dishwashers
I have a brand new Zanussi dishwasher. When I turn on a wash it makes noise as if about to start the wash. Then after 5 minutes it stops as if the wash is completed.
The first time I used the dishwasher it worked perfectly. Since then it makes noise as if about to work correctly and then stops after around 5 minutes. The light flashes as if it worked correctly. No water seems to have entered the washer and the tablet wasn't released. I have tried all different settings and made sure the door was properly closed.
  • Zanussi Master
  • 10,801 Answers
Since it is brand new, you should be able to request repair, replacement, or refund under the warranty.
Posted on Aug 21, 2018
    Top Expert:
  • Zanussi Master
  • 66,468 Answers
Sadly ,we do not have to ability to see your machine thru the net but if water does not enter that is the place to start looking for problems .
Anonymous
SOURCE:
Anonymous
  • 236 Answers
SOURCE: Dishwasher tablet not releasing
sounds like the dispenser solenoid is faulty you will need to replace the whole unit, this involves removing the door panel.
Posted on Jun 11, 2007
Dov Dror
  • 641 Answers
SOURCE: It seems to start, then stops after a few minutes..
Jon, check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck
Posted on Aug 13, 2007
DENNIS MITCHELL
  • 1003 Answers
SOURCE: Kenmore 587 High Temp/Heat Dry lights flashing, cycle not complete
REPLACE TIMER
Posted on Jan 18, 2008
Anonymous
SOURCE: Kenmore Dishwasher does not wash
my problem is the motor hummms for a minute or so and turns off. Could this be the capacitor? how do you test a capacitor?
herb
Posted on Jul 14, 2008
Anonymous
SOURCE: Zanussi built in aquasave zt 685
I think I had a similar problem to this. It seems like it was starting a cycle but then it just stalled and made a buzzing noise and it did not drain properly. I opened the bottom of the dishwasher where the draining pump was located. take off the plastic cover and I found bits of broken plates were jamming the fins on the pump... Try this and see how it goes.. Hope it was of some asistance.
Posted on Mar 09, 2009
Clean light is flashing 7 times, stops and flashes again. Can't make it started anymore.
my whirlpool is doing the same thing. I'm trying to find a wiring diagram with not much luck. A work around I use is to turn the breaker on the fuse box off for 5 seconds then back on. The dishwasher then works for one cycle.
Aug 09, 2015 | Whirlpool Dishwashers
My diffuser will not mist. The lights are on and it is running fine otherwise. What is the problem?
Did you use distilled water ?
Ours called for distilled water to work correctly, we used tap water and it worked for the first few times. then started making noise and then stopped.
Started using RO water, (like distilled) and started working again.
Apr 07, 2015 | Humidifiers
Dishwasher starts then pauses and drains.
Fixed! I had the issue where the cycle would start, the KUDS30IXBL8 would hum 4-5 times and then drain. Plastic folk pieces jammed in the disposer. These instructions took a few minutes (only 5 screws and a couple clips) to figure out how to take it apart, and it only took 60 seconds to put back together. How To Repair Dishwashers KitchenAid Repair Chopper Replacement
Apr 25, 2012 | KitchenAid Dishwashers
GE pdw9980lss dishwasher makes a horrible squealing noise when not in use.
The dishwasher control panel must be defective, nothing else would cause this.
Apr 04, 2017 | GE 24 in. PDW9980LSS Stainless Steel...
Whirlpool gen 2000 makes right noises on start up
check only the water inlet because it maybe weak then a timer of inlet stop after this time
thanks
Jun 10, 2009 | Whirlpool Dishwashers
Makes a funny noise
I had the same problem with my Triton XL Model # - GSD6660G02SS Dishwasher. I tried adding water, zip tied each wash arm (one at a time) and had no positive result. Then I noticed a notch on what is called the docking cone. It supplies water to the middle wash arm. When the upper rack is pulled out you can see the cone at the back of the washer. Anyway I put a rubber O ring on this notch and the noise stopped. I can't tell from the parts list if the O ring is supposed to be there or not. Maybe a GE repair tech can confirm this. Hope it works for you as it did for me.
-Mark
Jan 02, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Smeg Dishwasher
you may have a foreign object stuck in the pump. it may well disappear with time and it is an aweful job to get at
May 22, 2007 | Smeg 18 in. DWF410SS Slim-Line...
Dishwashers Logo
56 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Renee Knafel-Bullock
ray gallant
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
